Well I can bench, however I cannot orthos over 460 ish FSB on this thing. I never pulled the NB and applied AS5 like I usually do. Gonna try that and see, for some reason I think the board is causing orthos to die over ~460 Mhz fsb. I've had issues with multiple chips once I get to ~ 4.2Ghz (E3110, E8400) even with relatively low volts. Water cooling just CPU at this point on PA120.3 and DTek Fuzion. Also, the 9800 GX2 is a power pulling beast but I've got a TT ToughPower 1000 Watt PSU.
I'm using an Asus p5k-e with bios 1012.
Any suggestions??
http://3dxtreme.net/other/E8400%20Q7...48.29%20AM.jpg
