^ black is better! lol, mm I think I switched them cos some cable was going too close to it, but I haven't heard of any performance issues.
are you guys serious? black slots are better than yellow slots? I didn't know they would make a difference.
1st black + 2nt yellow = best overclock for 2x1gb here
Are you still in dual channel mode if you put it like that?
No he isn't :D
I have 0908 BIOS.Quote:
Originally Posted by Alexandrus
How is the o/c potential ?
I use 804, any o/c potenital difference among this two bios ?
Good for you, you asked where to get 0910 BIOS and I gave you the link, what part did you miss ?Quote:
Originally Posted by Ancient1
QFT! :fact:Quote:
Originally Posted by Millyons
BTW i'm amazed by how many ppl are still using onboard sound... :p:
Well.. I have used it for 3 months now.. I use stereo headset, and it sucks if I turn the vomume to max (or actually just over 50%)
the spdif for the hi-fi works fine.. .. and I need that part, so I can't just buy a cheap soundcard.
You can still get a Chaintech for $22 -Quote:
Originally Posted by cdelong
http://www.newegg.com/Product/Produc...MP=OTC-Froogle
Any findings on the 0910 bios ?
Isn't sound crackling fixed with latest drivers?
I am still using 4570, but i saw that Asus has already released 4580 officially for p5b-d .
There is no sign of crackling here, but that could also be because of low volume.
Can any moderator please start a new thread? This is the 108st page, and the startpost is ancient..........
sorry, pressed it twice
Anyway, i can make a new thread,
can we post all the problems (which are related to this board).......
-PCI express x1 issue.
-sound crackling
- best o/c bios
- jmicron controller and hot plug
- new strap , which results is worse performance
- cold boots
For the test I've ran on my system this bug only happens when I switch the NB voltage over 1.45v, beside that everything runs ok.Quote:
Originally Posted by hot_fifty
Hope it helps.
Jorge
Hi all, noob here with a P5B Deluxe problem
# Processor: E6600
# Bios Revision: 0804
# Memory: Crucial Ballistix DDR2 800 - 2x1GB sticks
# Configured Voltages: default
# Configured FSB: default (not overclocking)
# Configured Ratio: default
# Configured Memory Timings: default
# Any other applicable configuration modifications:
I've had my system together for a few months now and for the most part it's been running great, however, I've been getting some BSOD's for the past few weeks. I ran Prime95 and it failed.
Since I'm running 2 sticks I pulled out one and tested the other and it did not cause Prime95 to fail.
Shutdown and pulled out the supposedly good stick, and put in the remaining one for testing. Once I did that my machine would not post. So I pulled that stick out and replaced it with the first one and powered up but my machine would still not post.
After perusing various support threads I went out and bought a cheap stick of DDR2 from CompUSA and now my machine posts and boots fine.
At this point I went into the BIOS and upped the memory voltage to 2.10, shutdown, and popped in a Crucial stick but my machine still won't post with either Crucial stick plugged in.
Unfortunately I have no other DDR2 compatible motherboard laying around to test my memory so I have no idea if my Crucial sticks are still functional or dead.
Any suggestions?
push 1.45V through northbridge.....
If youv'e tried using only one stick in different slots, then there's not much more you can try. Keep in mind though that even if you have your voltage set at 2.1v in bios, right at first boot, the dimms may only still be getting default voltage till your settings kick in and it may be just long enough for it to not post. Try single sticks at 2.3v one at a time in both colored slots and if still no post, eiether try a new board or try ryour ram in another system if you can get access to one.Quote:
Originally Posted by jmr
Thanks for the feedback. I dropped off my RAM at a local tech shop and if they test out OK I'll give your suggestions a shot. If that fails then I'll just RMA the mobo.
Anyone know the changelog for 0910 beta bios or give it a try?
I tried it, nothing different for me, I had 0804, 0903, 0908 and now 0910, didn't notice any difference.
Have they updated the Jmicron or Intel Raid bios's?Quote:
The Jmicron has had a few updates recently.
thinking of coming over to asus from gbyte ds3, looking at p5b-dlx or the p5b-e which is cheaper. any suggestions from you asus guys? also, does asus have "auto" settings for voltages that automatically increase based on your fsb overclock? that's 1 nice feature of the ds3 that i like
