Are you SURE it's 1.52...
Check the Vcore measure point w/ a DMM to be sure. Mine 1.5 = 1.6 :eek:
1.5 is ok for longterm, I don't like 1.6 :down:
Originally Posted by masterofpuppets
1 hour 42 minutes of priority 9 dual prime now :) 2.8GHz @ 1.52v, seems a little high compared to some of these 0550's :( Does anybody know if running at this voltage 24/7 will do any long term damage to the chip, or is this voltage perfectly safe for 24/7 use? Just seems really high compared to these 0550's.
Temps are your enemy here.
Got 2 same stepping (Mine is CCB1E, what is your's :hrhr: )
Mine is running water @ 2.8Ghz / 1.36 Vcore (DMM) (Rosetta Stable :D ) Temp is 38-39c IIRC
Originally Posted by ablatt
I saw a post here at some point highlighting the meaning of the digits on the 3rd line below the CPU. Anybody remember where it is?
I have an Opteron 170 0550 VPMW, with the digits
1387678L50147
Is this a known good batch? I know the stepping has gotten favourable reviews.
Which part is the batch number?
Is the entire number the serial number?
I have an Asus A8N-SLI Premium and 1 GB of OCZ Platinum Rev 2 RAM.
I am able to get 2600 stable at 1.36 vcore (bios, PC Probe shows 1.39) using an XP-120C HSF. My dual prime load temp is 48 C. My RAM is set to 400 in the BIOS (1:1) at 2.5-3-3-7.
As soon as I go up to 2650 I have to slow the RAM down and my temps go up to 49-50.
This doesn't seem too bad but I was hoping for better.
I don't want to install water and I don't want temps much higher.
I tried a 0550 UPMW but it could not match the VPMW at the same settings.
So from you experts out there, how does this seam?
