Originally Posted by cjoe
What platform are you on? Intel? Amd? Give us some info.
They Neo probably had right near perfect rail values since Antec PSU's are very good at regulating voltage. The Fortron might be undervolting slightly on the 3.3v or 5v rail, whichever is used for Dimm voltage on your board.
Yeah, you maybe right. But I still think that the Twinmos is bad irregardless.
I'm a little disappointed by the Fortron PS also.
Need to burn in new Mushkin. Seems okay @ 220FSB 3.2V 2/2/2/6 1T 1:1.
GSkill LE stable up to 290FSB 2.8V 2.5/3/3/6/9 1T 1:1. OCCT & S&M still burning in.
I'm going to swap / test memory & power supplies.
CJoe
3.2 isn't really enuff to run twinmos at 2 2 2, I've gotten errors running 3.2 volts also whether it was 200 fsb or 260, but at 3.3+ they are flawless. after some burn in, they are really nice, (assuming you didn't get crap in the first place). They should be able to do 240 fsb at least for the pair, if your lucky, they can do 260+ with the pair, 512's now I'm talking about, not 2x256, heh.
What is the most STABLE settings for DFI and 512meg BH-5 ?
What values affect the stability most in bios ?
'You sure about that? :cool:Quote:
Originally Posted by fareastgq
Hit it iwth 3.4-3.5V and see how they act. They can be real squirrely below 3.3V.
@uwackme: My memctrl becomes confused before 260MHz. Memtest spits errors from 0.1MB to xxx.xMB. :cheer:
[IMG]http://forum.lowyat.net/index.php?ac...=post&id=53975[/IMG]
i'm buying this pair of RAM's second hand.
2*512mb Twinmos SP (UTT) PC3200 cl2.5
448W45M40570653 / 448W45M40570676
can you guys please check it out and see if it's good?
@benji: Those are week48... So are mine. Have had 3 pairs of these, all did or allmost did 250 @ DFI nF2 Ultra Infinity. On A64 they do it with less voltage.
To clarify, you may have cherry sticks, but for the most part, within the mean of supply, they cannot run 2 2 2 with only 3.2, or everyone would be reporting that they can run 3.2 volts at 2 2 2 flawlessly. ie: 3dmark/memtest/prime stable. Within the whole range, there have been sticks that simply cannot even boot with stock stable, and there are sticks like yours, lucky you :p:Quote:
Originally Posted by largon
I can run mine 2-2-2-X with 2.6V at 200FSBQuote:
Originally Posted by benji
goto to love that tvtorrents, i know I do :toast:
I noticed my Speed Premiums very dependant on some timings, for example tREF@ 3120 or 4672 they just couldn't do 230 even 3.4V. Changed tREF to 1168 and BAM! 250MHz (2-2-2-5-7-15-2-2-1-1-1168-1) with just 3.2V - no bandwidth loss with this setting.
That gives 3033MB/s in Memtest 1.51.
Glad I didn't frustrate before figured out tREF's impact on OC.
Okay. I'll bump up the voltage and set the TREF to 1168.
I'm also burning in my Mushkin Blue Value (Fry's). 8hrs @ 2/2/2/6 1T 1:1 215FSB 3.3V. Memtest86 in general is error free but test #8 avgs 4 errors per pass still. How much burn in did you guys do before the memory became good?
144 hours in a row @ 3V + 9 hours with current timings and voltage. :flame:
Largon: U the man!!! You're right. After setting TREF=1168, Memtest is much cleaner. I'm going to increase the FSB and let it burn for a couple of days.
What is the current prevailing concensus about Twinmos Speed Premiums vs. Mushkin Value Blue? Which one seems be be better in general?
I have the AA4T / 44D SP and BP815 Mushkins (I haven't opened them up yet).
Thanks...
CJoe
I'd go with those AA4T/44D Speed Premiums over the mushkinsQuote:
okay,i'm buying them later in the evening.
thx guys.
Can you let me in on it?Quote:
OOps, I got it. 1168 seems to be the ticket for my mushkin blues(green) too
Or does it?
musk
What were your settings at 3V?Quote:
Were you able to run 2,2,2,6 with > 3.3V immediately after purchase?
I can post at 2,2,2,6 with > 3.6V but memtest #8 registers thousands of errors.
My Twinmos SP are stable @ 240FSB 2,3,6,3,7,15,2,2,1,1,1168,1,E 1T 1:1 3.4V. Does this seem normal after 10hrs of burning? Will they continue to improve after more burning in?
I would be delighted if I could achieve 260FSB 2,2,2,6 @3.4V.
Thanks..
Cjoe
Bought them (6 sticks, sold 4) few months ago. First month they ran 240-250 2-2-2-11 on DFI nF2 Ultra Infinity with 3.3V. No fan. :cord:
3.3V was top vDimm on that board. Board did actually die just few days before I was supposed to solder the vDimm mod. Had already put it together separately.
Mem fets were just vaporised overnight.
144hour burn:
If I remember correct it was 225 2-2-2-5 @ 3V w/ Memtest86+ 1.51 + 92mm Zalman fan keeping the temps down. Left Memtest86+ running through #1-"8 for 6 days, not a single error.
Guess nobody is able to tell will your sticks improve... who knows, maybe they will, maybe they won't.Quote:
Just make sure they don't get fried.
tref 1168 could be working also for WINBOND BH-5 1A4T ??
I have burned my BH-5 stick for 3 weeks.
It improves alot first 3-4 nights after that you gain 2-3 mhz on week.
Last week nothing has happend.
Burning ~10 hours a night.
*edit* Tref 1168 was real good! (DFI NF3 & 1A4T 1X512)
Could do 265fsb 1.5-2-2-4 Superpi 8meg.
Been messing with that all day and now it did it right away.
LARGON RULES :toast:
@Ubermann: :toast:
