Notice the little "(im playing devils advocate here :p)".. Im far from being a Charlie Zealot.. On the contrary :yepp:
GTX4X0 3Dmark06 benchmark leak:
http://img.photobucket.com/albums/v4...3DMark2006.jpg
http://www1.uwants.com/viewthread.php?tid=9547178
1600mhz memory?
Means little with 0mhz core, though :p
Hummmm
The GPU-Z now will display GPC Clock or ROPs Clock in the "GPU Core Clock"? :confused:
Rumors...
So it seems Nvidia did reduce the TDP. It's 250W for the version with 480 cuda cores.Code:470 480 480U GTX
448 480 512 Cuda Cores
56 60 64 TMUs
40 48 48 ROPs
1280 1536 1536 MiB
320 384 384 Bit GDDR5
225 250 270 Watt TDP
Where are these rumors from ?
I don't think they are correct. TDP difference should be more between 470 and 480.
gpu temprature 34c and the fan in 79%??? wtf?
The bad thing is its SLI score not single card.
Actually 3DMark06 does not work very well with CF config's, my pal has 5870 CF and together score around 204xx and a single card scores around 19xxx at 1920*1200.
If this is dual SLi i am a bit impressed and if Nvidia is not using any dirty tricks.
http://vr-zone.com/forums/580572/one...umes-305w.html
According to those news (which have all originated from a DH article) the GTX 480 will be 298W TDP in its stock version
Edit: Actually it might be single card , CPUZ and GPUZ display single and multi cards differently. :doh:
Does anyone have a 5870 that can run that 3dmark 06 pro benchmark, so that we may make a comparison? (stock 5870, 4.2ghz i7, 1920x1200, features tests) Thanks.
According to overclockers club (not my favorite review site ...), a 5870 with 3GHz 920 scores around 20000 pts.
But this site isn't top reliablity IMHO ...
Who cares about 3dmark06, i dont play 3dmark06, lets see some Battlefield Bad Company 2 benchies, since its the hottest game right now, lets see some DX11 comparison's with 5870 :up:
I don't have a 5870 but this might help...
http://www.tech-caffe.com/gfx/3dm06.jpg
http://www.tech-caffe.com/gfx/3dm06_5970.jpg
EDIT: I noticed only now that the test is at 1920x1200 wtf??? Either too much speed to be true or the video card is a BLAST!
Here you go. I will try to get this thing running with turbo and HT but I've always ran without (so far It appears I'll need over .75v more just for HT and 200Hz, not worth it... anyways) as appart from benching and AV work, its pointless ( I am a gamer not a bencher )
This was ran with the system in my sig ( same clocks / relavent info ) using Catalyst 10.3 previews.
http://img689.imageshack.us/img689/2...8709255ghz.jpg
Look at the feature test numbers that are visible... quite interesting.
@ Namco and Chickenfeed: Thanks!
@ mindfury = VANTAGE Please !
@NaMcO : Resolution is 1920X1080 on mindfury's link.
I'm not really sure that GPU-Z 0.3.9 supports Fermi's models though ... W1zzard, a comment, maybe ? :D
edit : Thanks Chickenfeed :up:
