Zen;
can i get your bios settings? looks like we have similar setups..
Zen;
The piotnoir , i read that its going to be both 790 and x48 variants
Both work fine Tiramisu... I ran the Q6600 on 0907 and also with the QX9650 no issues... updated to 1003 hell broke loose... reflashed back to 0907 all fine, now tested 1004 and it runs fine with Q6600 and my Gskills 4gig kit... no worries... I think Kup advises to use 0505 for Q6600...
1. boot from usb
2. AFUDOS /RF0219.rom /pbnc /n
3. done
correct? just to confirm :P
alrite got it thx :)
would anyone care to share there memory settings?
that pull in/out isnt making sense to me, If I play with it I get the "det dram" hang, then it takes forever b4 the pc will boot again.
Frustrating as hell. Finally had the Maximus sorted now its back to start again with Rampage
yes but without actually changing the internal mobo timings i guess....
correct me if i`m wrong..
Check this out about Rampage settings:
http://www.anandtech.com/mb/showdoc.aspx?i=3208&p=3
im with Grnfinger here too...
im getting some mixed results. DET RAM errors all over the place with similar settings i had used on the maximus BIOS... on the other hand however, cpu voltage is now lower, and amazingly, my load temps dropped 2 Celsius on full load~!!
its easy...imagine that you give pl5 with all phases disabled...you still have pl5
if you give pl5 with phases enabled you actually have pl4......
soooo,with fe 400fsb you`ll work with pl5-disabled...but not with pl5-enabled...too tight..
1. Absolutely NO personal attacks.
Flaming or inciting flaming (also known as flame baiting) will not be tolerated, no exceptions. This includes references to bodily harm/violence.
17. Private Messages (PM)
PMs are just that, private messages. Any member posting a PM to the boards without express prior written permission from the site owner(s) will be immediately dealt with, and the post will be deleted. Spamming to PM boxes is earn you a permanent ban.
I presume these rules are still clear (in case some of you have forgotten them).
Keep it clean, thx.
flame bait... lol sounds like an underage homosexual. (no offense to anybody, i just thought it was funny)
This looks promising I'm not sure If I have time to tweak everything again though. /sigh I wish Asus would release a decent bios for the Maximus Formula but when I get more time I suppose this hack is in order :) Thanks for all the work on this guys, this is a thread to follow.
Sorry double post here.
Just loaded 219 and my bandwidth is :banana::banana::banana::banana:. Same setting and major crap here.
If I post my memory setting can someone with a tad more understanding of these new bios settings hold my hand and walk me through it?
Grnfinger;
hehe
also,
i just upped my B/W by a bunch....
send me ur mem settings and ill compare the 2 of ours.
http://img132.imageshack.us/img132/4...ememsm2.th.png
^---- still worse then my maximus bios by far...
w/ maximus, i was lookin at about 9600 M/B/s :(
