"4-4-4-4 timing"
I don't see it being possible.
"4-4-4-4 timing"
3-3-3-6 and 4-4-4-8 i've no problems with
So, bios 0802, how is it? Quads overclocking any better? Higher FSB?
I've no idea what i did differnt or went went wrong but BIOS only allowed 2 cores, then i uped it to 520FSB and only 1 core showed!
http://img.photobucket.com/albums/v6...#37;20G0/2.jpg
Then i got it working and my max so far
http://img.photobucket.com/albums/v6...600%20G0/3.jpg
701 BIOS still, my 1st 500FSB with this bord!
Can ya call me dude please? Just friday is exactly 12 month ago i lost my little bro so bit raw!
I've really no idea how the hell i got 500FSB, l;east i know my bord can and will do it i guess, but more so i wana know why it didn't do it with all 4's.
I think i got it writen down so i will try and find it, be latter as im off to the hopsital for my post op checkup
0602 ---> 0802
9X400MHz
FSB Strap: 400MHz
DDR2-1066MHz
5-4-4-12-3-30-6-3
8-3-5-4-6-4-6
Everest
Rd: 9110 --> 9079
Wt: 7303 --> 7262
Copy: 8173 --> 8150
Latency: 55.0 --> 55.0
Also the same CPU temp issue that was present w/ 0701 appears unchanged in 0802.
I haven't checked any of the other straps yet. I hope I can finally get stable using a divider on the 333 Strap that would definitely help memory speed.
Life has to go on
Dude don't worry about, Pete, dude, fella, guv, gav, gezza, anything and everything but bro is cool man. Really don't worry about it, take a lot to p me off like this mobo, least i got 500FSB out it at last
0802 still seems to have the divider issues somewhat.... I am still reworking..
Any change logs yet? they must have loosened the NB timings again, or changed the way the performance options work because now I can boot with DRAM STATIC READ and DRAM CLOCK TWISTER set to Enabled/STRONG.... had to set Transaction Booster to Disabled (1) to get it stable.
My speeds went up at 450x8 DDR2 900 4-4-4-8-3-25-3-3-7-5-4-6-4-6
:up:
No good news.
with all bioses incl. 0802, i can not boot a stable vista x64 system with:
4x 1 GB Corsair Twinx2048 XMS2-6400-C4@400 MHz@ 2.1V@5-5-5-18
(2 Kits)
If only 1 Kit are installes (= 2 GB) System and Board works very fine.
Anybody using a Creative soundcard in the first pci slot?
Hi, this 0802 bios seems better for me, dialed in 375x9 and it booted. I haven't had to change any other settings from my 356cx9, vcore is 1.34 according to probe and temps seem fine. Never been able to get this oc without silly voltages before so fingers crossed...
Chris
