vmch mosfet shown here in this post ,bottom picture:http://www.xtremesystems.org/forums/...15&postcount=5
Good grief...I just looked at that mod a little while ago. Thanks jimmy.
Hi,
which driver choose for install Seagate Barr. 7200.10 320GB SATA2 in begin install win after F6
- Intel(R) 82801HR/HH/HO SATA RAID Controller (Desktop ICH8R)
- Intel(R) 82801HR/HH/HO SATA AHCI Controller (Desktop ICH8R)
- Intel(R) 631xESB/632xESB SATA RAID Controller (Workstation ESB2)
- Intel(R) 82801GHM SATA RAID Controller (Mobile ICH7RM)
- Intel(R) 82801GBM SATA AHCI Controller (Mobile ICH7M)
- Intel(R) 82801GR/GH SATA RAID Controller (Desktop ICH7R/DH)
- Intel(R) 82801GR/GH SATA AHCI Controller (Desktop ICH7R/DH)
- Intel(R) 82801FR SATA RAID Controller (Desktop ICH6R)
- Intel(R) 82801FR SATA AHCI Controller (Desktop ICH6R)
- Intel(R) 82801FBM SATA AHCI Controller (Mobile ICH6M)
If raid then - Intel(R) 82801HR/HH/HO SATA RAID Controller (Desktop ICH8R)
If non-raid then - Intel(R) 82801HR/HH/HO SATA AHCI Controller (Desktop ICH8R)
thanks for reply ;-)
I'm not in the sound card business, but what's a good decent cost card to get rid of this crackling?
$40- $50 tops.
I'd say audigy 2 but those are very hard to find and the ones thats out there the higher end one is nearly the same price as the X-Fi ones.Quote:
Originally Posted by cdelong
so an Audigy 2 ZS Pro is pretty good? Not the Platinum Pro with the front panel... just the Pro version.
Friend just put together a C2D rig using the Asus P5B Deluxe and had an Audigy 2 card. He's getting tons of crackling and pops when using that card, even when rolling back one of the MS updates. He's trying out the built-in audio now.Quote:
So it was a MS update that crapped out on it? I run an Audigy 2 card no problem at all.Quote:
Originally Posted by BRiT
So would it be worth $25 to try it out?? I found one on another forum for $25 shipped.Quote:
Originally Posted by deathman20
People with crackling sound.
Try this. This solved my crackling problem.
Disable DTS.
http://ferry.lghosting.nl/bestanden/dts.JPG
I thought new sound drivers solved that?
PCI-E 1X problem fix maybe it issued here already.
1- pci-e bus put 105
North bridge
2- peg force x1 disabled
3- peg link mode normal
4- asus c.g.i. disable
SB
5- pcie.... 4x mode (fast)
Try it helps to resolve P5B DELUXE 1x problem. :banana:
my PCi-E 1x problem is solves by: 1,45 on NB, 1,6 on SB and 1,3 vFSB
yes i agree. I have corsair 8500c5 and ocz flex xlc sticks. It seems to only be the sticks that have been in the second slot for a period of time. On a restart system will not post. If u take stick out of second slot then it will post but goiing to bios and messing around with the setts there does not help. What i need to do is boot into windows with the 1 stick in the first slot and then shut down. Without turning of PS i insert the second stick and then it will boot. Also it seems that the sticks that have been in the second slot get slightly damaged in some way. Because they will not boot on there own in any slot only can boot with single stick that has always been in first slot into windows shut down and insert the other in second slot. then it will boot. using older corsair 5400c4 sticks and no issues at all.Quote:
Originally Posted by xgman
You can find , in USA, X-Fi XtremeMusic OEM for ~$65 , there's another cheap version of X-Fi which i forgot its name..Quote:
I read AuzenTech are good too.
Regarding mobo FANs . I'm using SpeedFan and I'n not able to control the 3 CHA fans seperately ! I have Q-Fan Disabled in BIOS. Thought you might have a clue/hint/solution ? :)
THX
Originally Posted by Severance
if you are pulling or installing sticks without powering down your power supply then you are killing your ram ddr2 needs all the power on the board to be discharged before removing or installing ram. there are several threads about it and besides it is just common sense the board still has power supplied to it even though it is off that is why it has a light that says asus is to remind you that there is power live in the board. that is why your sticks are damaged.
if i turn power off and install second stick..it wont boot because it uses stock settings in bios that does not give enough voltage to memory for boot. The ram that needs to be removed and reinstalled was having this trouble long before i figured out how to finally get it to boot. If it is hurting the ram i cant see anyway to do it without leaving power on. I have let it sit for hours with all power off and still wont boot with second stick untill i do what i said. also somewhere on 1 of these 100 pages a guy killed 2 setts of high end ram with this board i gonna search for it.Quote:
Originally Posted by jimmyz
Audigy 4 here without any sound issues.....100x better than the onboard...lol i never cared to much about sound until i got this board and i just couldnt stand it and got the audigy
I got an Audigy 2 ZS on the cheap from AT. I see how it goes.
If i desable dts then the sound is fine. wierd its not working for everyone. just installed 910 bios no difference to meQuote:
Where do you get 910 BIOS from?Quote:
Here you go : http://starjojotrek2.free.fr/BIOS/
What are the best slots to put 2x1gb sticks in? I have mine in the yellow slots.... would black slots be the same?
I'm just going off my old DFI NF4 SLI-DR board where the orange slots were better than the yellow slots.
