Anychance of some results before Monday? When are you actually getting it.Quote:
I am offerd to buy either a CABYE 0536 and a CABYE 0540 same price, wich one is the best choice for the biggest overclock at the lowest voltage?
CABYE 0540 would be the better choice.
Almost all of them can reach 2.9-3.0 Ghz at low voltage.
The 0536 aren't that good.
wiker : like jupiter said ;)
Ok thanks for answers, I´ll take the 0540 then :D
is it very likely to reach 2.8ghz with a zalman cnps 7700 air cooler?
very likely.
Originally Posted by shimmishim
I just got an Opty 148 and have the same memory as you. Try the following settings:
MAL/RP
9/7.5
9/7
8/6
8/5.5
Good luck
thanks RafaDel
Finally got my Opteron in the mail, even though the tracking number says it hasn't shipped yet ...
Opteron 146
OSA146DAA5BN
CABYE 0540FPAW
Will have results next week with the new SLI-DR Expert board ...
--Nathan
With my TCCD i can run Max Async Latency at 8ns and Read Preamble as low as 5.0ns completely stable.
i've been noticing weird reports with temps on my CABNE's.. right now, i'm at 1.15v, load is 31-32c at 2.4ghz. the water temp in my loop is reported at 31.5c with a sensor i tend to trust :stick:Quote:
Originally Posted by largon
Where'd you get it?Quote:
Originally Posted by nloding
Well, there are serious suckers around in Opteron-land ;)
Had a 144 to play with. well... 2.8GHz was almost impossible. Required > 1.6V on water. I like my 4000 better :)
144: CABNE 0540BPMW
4000: KAB2E 0533RPMW
2 screens to support :)
Screen 1
was sick of trying to prime @ > 2.7. Really not stable.
Screen 2
capable of 3.0GHz prime < 1.6V :p:
this one is naked btw.
any ionfo about this stepping : CAB2E 0540 FPMW
ChkDsk : You couldn't reach 2.8ghz on a CABNE with water?! I find that highly unlikely...have you considered removing IHS and/or remounting?
Problem is, bought this one today for a friend of me. So its highly unlikely he would like to see me undress his CPU :P As you can see temps are ok. But tried almost all memory dividers, higher chipset voltage etc. But the CPU wanted more and more volts. Stability increased with more volts but I was aiming @ 2.8GHz @ +/- 1.5V so I could trade with my 3700SD.Quote:
Originally Posted by DamienKC
Too bad...
[EDIT] BTW, tried >310MHz HTT with my 4000 (and divider) and works perfectly. So, for now, I blame the Opteron :( [/EDIT]
Well I just took a trip to Monarch after work...
They still have some good steppings.
I have an Opteron 146 CABYE 0540FPAW :)
I googled my stepping, and someone managed 2.9 GHZ on stock voltage (scroll down a bit):
http://translate.google.com/translat...icial%26sa%3DG
If necessary I will post pictures of the package for verification.
EDIT: Oh, and I can confirm they DO have the SLI-DR Expert in stock, though I did not buy one today
deception``
OMG
NEWEGG 209$ for 146
thats about average for a cabne 0540Quote:
Just did a quick test to 2 144 CABYE 0536 GPMW. I used a friends dfi ultra because I am waiting for expert. I was a little confused with the thousands of settings :p: but I managed to get them both to 2800, super pi 8M stable with 1.5 and 1.525v bios (1.47 & 1.5v smartguardian) with stock cooler. Didn't have more time to test. Not superb, not bad either :D
Edit: Sorry, Ed: I'm a jerk.
On Topic. I'm working on getting my TEC'd 146 to 3.1Ghz stable. May have to wait for a new PSU and a 400mi move.
Well... finally after a long time waiting I received my Opteron 148 from Compumusic, not they are slow but I had to use a friend to bring it to me in Brazil...
Overall this Opty is promissing...
CABNE 0528GPMW
Right from starting I could easily get 2860 at default voltage, my problem is the HEAT. It gets too hot running Prime, even at default voltage ~60C with a XP-120. That's may be because the 148s have higher temps I guess.
I dont want to invest in some more complicated cooling options so I'm kinda stucked here. I may replace my ThermalRight with a Big Typhoon but I dont believe it will help a lot.
mine arrived todayQuote:
Originally Posted by 187(V)URD@
OSA146DAA5BN
CAB2E 0540FPMW
i only need one tho... so far at stock volts two pass occt 1/2hr @ 2.83ghz, one passes @ 2.85ghz... max occt 1/2hr 3.07ghz, max suicide 3.118ghz...Quote:
Originally Posted by TEDY
still testing... it's like round the clock overclocking in here... 3 new cpus, and having to re oc my venice because i moved it into another rig... trying to get my 2.92ghz back on that one! :D
question and sorry if it's slightly off topic here.
i'm testing my cabne 0530apmw chip but i'm having some stability issues.
3.0 ghz with the 180 mem divider allows me to pass 32M superpi and OCCT 30 minute test.
3.0 ghz with the 180 mem divider crashed windows about 3 hours into large fft prime95 test.
retested 3.0 ghz with 166 mem divider as to eliminate the possibility that it was the ram. ran prime95 large fft for 6 hours+ before i stopped it.
decided to game and my game hard locked 2 or 3 minutes into it.
so i decided to test small fft prime95. it generated an error within 4 seconds. reran it again and generated an error within 1 minute.
the question is...
what tests constitute a processor as being stable?
people swear by large fft prime95 while others say small fft prime95 while others say other tests...
what test methodology do you guys use in order to consider a cpu stable for 24/7 use?
back onto topic
the 0530 apmw chip is pretty amazing. i'm using small fft prime and it is running 2.9 ghz with just 1.44 volts but temps are running warm at 55C's on my watercooling.
