thanks stasio, for P67A ? not fixed ?
yep works ok on p67 i'm still using my b2 board flashed with the z68 bios and all working as it should:up:
http://www.gbwatches.com/pics/8fbios.jpg
Your CPU-Z show still P67A and Vcore is probably OK.
As me before,when I first time crossflashed to Z68.
2 weeks ago I flash back to P67,testing something and crossflashed again and suddenly CPU-Z show Z68X (Vcore wrong).
Somebody will try for sure,another 2-3 hours.
stasio
MEM fixed on F5e ;) here's proof
http://img855.imageshack.us/img855/9067/50152133.png
Next i will try Touch BIOS
Flashed as backup all runing ok for now
***edit TOUCH BIOS NOT working same as before soft reads all but wont let me enter to Volts settings crashes there here proof
http://img850.imageshack.us/img850/6717/capturadn.png
Uploaded with ImageShack.us
cheers !
Sergio
What was wrong with the memory on other the BIOS version then?
Because i am noticing something strange with my memory latencies....
In my BIOS the Latencies are set to 7-8-7-24 and in CPU-Z, AIDA64 and Memtest86+ v4.20 it shows up as 8-8-7-24. :?
Right now i have F5 on my Z68X-UD7-B3 but F7 is the latest.
Should i flash to the latest version?
What about the vcore offset? Is it possible to use simultaneously the vcore offset with multi LLC?
It was possible with f3h but not with f4.
sup jacek
the only time i used that feature i almost killed the chip lol i put a wrong number and went up like crazy so i never use it again
im waiting LLC7 to by stronger than on F4 testing it right now as even having same LOAD i need than on F3H i have BSOD on IDLE with new bios releases...lets see now
cheers
Sergio
well stasio
i really quit its really painfull, bsods on IDLE with this bios exact like F4...touch not working again no matter what...F3H still seems the best BIOS but i expected a bit more work from gigabyte since we dont only bench, those new bios are nice for bench but really painfull for 24/7 at least on my tests...
cheers
Sergio
Every JZ BIOS for me (on Z68x BIOS) set at 1.66V,in TouchBIOS show 1.68V.
ET6 is OK.
Btw,
anybody on latest ET6 B11.630.1,showing LLC levels only "Default".
Previous B11.512.1 is OK.
http://ggts.gigabyte.com.tw/ClientUs.../B11.512.1.jpg
http://ggts.gigabyte.com.tw/ClientUs.../B11.630.1.jpg
Note:
Please note that this beta BIOS is still under testing and not approved by GBT standard test procedure .
Touch BIOS Utility B11.0720.1
http://download.gigabyte.eu/FileList...touch-bios.exe
with the oringinal 3 levels of LLC, found in previous BIOSes such as F3H for the UD7-B3 it is possible, but when they added 10 levels for more control it sacrificed DVID offset at teh same time.
What does "Improved LLC" mean? Does it mean that you no longer get massive undershoots or overshoots with LLC6 and LLC7 anymore or something? So cryptic....has anyone tested the voltage spikes? F3G/F3H had perfectly predictable and steady vcores.....(load about 0.012-0.016v higher than idle at LLC2 on UD5/UD7 B3's...)
