DFI LanParty LT X48 T2R +2st Sapphire HD 4850 problem
I everybody (hi dr nick).
I hope that there is someone out there who will be able to help me. I have a DFI Lanparty LT X48 T2R board and i was running a 8800 GTS 512MB video card but I got a good deal on two Saphire HD 4850 Dual Slot cards (the one that has a new cooler that looks like the intel stock cooler). So i figured I would try running some crossfire action.
Well. I unstalled all Nvidia drivers and installed the Catalyst 8.11 drivers (win XP SP2) and tested the first card. I got some nice results but the fan seems like its running amost full speed all the time. The temperatures are great (40-45 degrees idle) and even if i set fan speed to 20% in CCC, the fan spinns down some, but still sound WWWWAY more then my old 8800 GTS. Anyway i then insrted the secound card and the fan is the same on that card to. I also installed both crossfire bridges. Uninstalled the drivers and reinstalled them. I got a nice little message that told me to enable Crossfire, so i did. I checked GPU-Z and both cards ar listed and crossfire is enabled. However one of the cards run at PCI 4x only. The other run at 16x. Well i started 3dmark03 just to test the performance. The loading screen for the fiorst test was REALLY slow and the test got me about 20-40 fps in 3dmark03! I aborted the test and disabled crossfire and tested 3dmark03 again. Now i get abour 500fps. So it seems normal. I the tried to remove one of the crossfire bridges and this time i get 16x on both cards in GPU-Z but the bad performance still persist. I also unsinstalled the drivers and reinstalled them, no change. I testeted v 8.10, still no diffrence. I have tried the lastest intel chipset drivers. Still the same. Im clueless. I dont know whats wrong. Anyone got any idees?
