hi
few more tests with orthos:
E8400 - 9x478FSB @ 4300mhz 1,40v full
http://img519.imageshack.us/img519/7...0orthoskt8.jpg
for 4,4ghz he needs 1,45v to be full stable.
regards
hi
regards
Q749A owners ? :)
Q806 doesnt seem to be verry good
1.39V 4.18GHz Superpi 1M Stable, this is done on the stock cooler
What did you set it at in bios?
anyone got a retail 8400 from newegg recently?
they have em in stock for $199.99
any results on those?
am wanting to pair one up with a dfi dk p35
I bought mine on April 7. The more recent ones don't seem to be clocking as high. They require more voltage. I'm not gonna give mine any more voltage until I'm ready to replace it.
so basically ... the good overclockers are the ones people got in the previous batches ? at launch etc ?
these new ones kind of suck ?
same question i was about to pull the trigger myself on one of these and now im worried i will get a crap chip..
well, crap chip is a bit extreme ... its the oc bug going trough us that want to see an actual 4ghz .. but oh well ... 3.6 ghz is more than I enough I suppose
edit: here , i got this from reviews on newegg
4/22/2008 4:04:06 PM Too Many years My first Intel
Pros: 3.6 right out of the box,Temps in the low 30s, 1.21volts Plus fast shipping
Cons: None Yet
Other Thoughts: Paired this with an IP35pro-8800GTX and 4GB G-Skill Good Bye AMD for now
So basically just like i said 3.6ghz
Changed back to the E8400 last night from Q6600. I was 4050 450 x 9 @ 1.29 bios, played COH but failed prime fast (few minutes).
Now 1.30 load (can't remember what it is in BIOS @ the office now) and stable. On my 780i this chip benched @ 4.5 but with way more core.
Volts above line cal enabled, sb, sb 1.5 auto, core 1.31, vFSB 1.36, NB 1.55, strap auto, ddr 2.3 900MHz (dominators default 2.2 @ 1066 so I keep it set @ 2.2 in bios, MB over volts it .1, so I don't get a hang det ddr).
I'll start pushing it tonight and hope to see 4.5 - 4.6 @ 1.4 to 1.5. Thanks!
Dave
q807 - 4ghz at 1.296 :P
q807 pownz.
