finally got 3.6Ghz occt stable. the only voltage I had to change was the SB voltage from 1.1 to 1.12 to give me 1.15 actual(for USB to work right).
I should add that vista x64 installed with 4GB no problem.
My Ballstixs are not playing well with these motherboard at all. Sometimes I have to remove one stick to get the system to post.
WB have you tried 0701?
hey warboy is that 2x1GB or 4x1GB?
I have just put my new board in the case and hooked everything up. I cannot find the connector to the front audio/mic connections. The manual mentions how to set the bios settings, but I did not see any reference to the connector on the MB.
Thanks Kup for the quick response. I was looking on the board and not there. Didn't see it in the manual either. Thanks again.
To test system stability would it be best to stress it out to the max? When I run Prime95 or OCCT I can still perform most simple computer tasks. But if I start OCCT's CPU and RAM test, and then Prime95's Blend, I can't do much of anything. I don't really know if this works to know how stable my system is running. I'm just thinking if there would be a problem that’s when you would know.
you can change the priority level in OCCT.
Yea mine are the same. I actually had to buy a stick of value RAM to get this motherboard to POST for the first time.
The reason is that Ballistix need more voltage than 1.8V (DDR2 standard) so I have to install 1 stick of DDR2-667 Kingston Value RAM, POST, go to the BIOS and set the VDIMM to 2.16, reboot, enter the BIOS to check the VDIMM, then hard shutdown and install my 4 sticks of Ballistix. It WILL NOT boot any other way for me!
omg i have to agree with that changes in the asus web...
http://www.asus.com/999/images/products/1850/1850_l.jpg
Its probably just a revised heatsink though. Might even be the elusive REV. 1.03G :D
bah i hate this went it happen btw new bios up....0802
ftp://ftp.asus.com.tw/pub/ASUS/mb/so...ula/MF0802.zip
Memtest will only test, not stess, it does some read/write routines and blocks. If there are some physical damage it will show easier in Memtest as it can test quiet all the RAM when launched from a boot CD.
Prime in Blend mode or even Large FFT, and OCCTP in RAM mode, will both stress the RAM-NB: just look at the heat on the NB and your RAM sticks generated by OCCT. But, they can't physically test all the ram as they run under windows, so they can't access certain memory areas reserved or alrady occupied
BIOS v0802, it's not up on US sirte yet. as of right now , 12:45AM on 11-19-07. Where did you guys find it? ASUS BIOS history list it as latest but not showing as available to download yet.
As for that RAM issue on this mobo. Half the problems you guys are having is likely the Strap and RAM deviders.
@ the guy who "I can't even post at 2.6volts with 4-4-4-4 timing and a clock of 1050mhz no matter what memory strap.". 1st off, that's a lot of volts for this RAM. I have the same and 2.34v is pretty hot already unless you're gonna go water or heatpipe w/ extreme fans. 2nd, if on BIOS v0701 still, I couldn't get anywhere with manual strap with 1:1. Had to leave strap and RAM frequency in Auto to get it to POST and get 1:1 (confirmed in CPU-Z). Also, if you're looking to OC on this, stick with 2 sticks of 1 g each for 2gb kit total for best OC stability and goopd timings and performance. 4 sticks can work but w/ reduced timings and of corse not best for OC'n too high. Just my experince on past few Itel chipsets.
Good luck!
omg...*smacks forehead*
I have no idea OMGZ i'm so wrong about everything OC. Someone should assassinate me. /sarcasm off
You are just feeding me common knowledge...You know these right? If you look at my P5K records, I was able to get 1350Mhz 2.5 volts easy, 5-6-6-17 timings.
And Yes If you read though these thread I have Hardcore air cooling. I got a 8800GTX to idle at just 40C with stock cooling. A Highly overclocked Quad to run at 27C, So please....
I have 2 x 1GB sticks...I've stated that a few pages back too.
