here is mine arecooled home server :)
P4 630 @ 4Ghz with Scythe Ninja Plus
7900Gs With Zalman Vf1000
http://img210.imageshack.us/img210/3...0070rj5.th.jpg
http://img227.imageshack.us/img227/9...0072sc0.th.jpg
Great job Rockford
I have the same idea, more simple of course, to my next PC
kohn.ma, that is just nice! hot swappable drives? :P
good stuff.
Hugeness :D
:welcome: kohn.ma, fungry.
Nice system you got there kohn.ma, is it a web server?
My sample of the new Accelero Xtreme arrived a few hours ago :D
http://www.abload.de/img/acceleroxtremeovpgbg.jpg
http://www.abload.de/img/acceleroxtremeoben2ys1.jpg
http://www.abload.de/img/acceleroxtremeheatpiyyi.jpg
Tommy OMG:D:D:D
Lucky meenn:D
review sample , or purchased "sample" ?
@Demo: Review sample of course ^^
i swear ive seen that video card before http://smiliesftw.com/x/hsugh.gif
Hey Steffen what are you using for lighting?
Some more pics of my little monster :D
http://www.abload.de/img/acceleroxtremeschrghukj.jpg
http://www.abload.de/img/acceleroxtremeseitlimqe.jpg
You call that a 'little' monster?
Does your little monster fit on new G92 also?
i think its overkill for my old 8800GTS.. its dam cheap and dam cold cooler
more info on that cooler please!!
so no 8800gt and new 9600gt?
Just more picture with details
http://i261.photobucket.com/albums/i...henutz/xcv.jpg
http://i261.photobucket.com/albums/i...tz/xdczvdf.jpg
Amazing Enough, A HR-09 Type 3 perfectly fits onto HD3870s with push pins
http://i261.photobucket.com/albums/i...enutz/uiou.jpg
Side panel FOamed up
http://i261.photobucket.com/albums/i...utz/trgjgf.jpg
as you can see, foam is wedged between the pexi and side
http://i261.photobucket.com/albums/i...enutz/sfsa.jpg
Every section you see with foam comprosed of 3 layers
1. Silicone adhesive which very easy to remove
2. Neoprene sheets for adding mass and make easy clean up if I remove the foam
3. Either I use Sonex Acoustic (melamine foam, white) or Some inexpensive cellous foam (sponge, commonly found in black) you can get from any computer shop
http://i261.photobucket.com/albums/i...henutz/oui.jpg
Finnaly after weeks of searching this somewhat rare long crossfire cable, asus includes them in their High end AM2+ motherboards and I was able to get this cable off of ebay :D
http://i261.photobucket.com/albums/i...nutz/fsDFD.jpg
the other side panel
