Originally Posted by
unclewebb
With hyperthreading turned on, RealTemp 2.85 should be reporting your core temperatures correctly.
Do you know if hyperthreading can only be turned on or off in the bios or is there a windows based program that can access hyperthreading. As far as I know, I think you can only adjust it in the bios.
Now that I understand what's going on, I should be able to come up with a fix. I have another feature I'd like to add at the same time that might allow the SkullTrail guys to access the temperatures of their other 4 cores.
When hyperthreading is enabled, the Core i7 Tester program shows the temperatures from all 8 threads. There are only 4 cores so threads 0/1 share the same temp data for core 0, threads 2/3 for core 1, threads 4/5 for core 2 and threads 6/7 for core 3. That should line up with what RealTemp 2.85 shows.
RealTemp 2.84 was only showing the data from threads 0/1/2/3.
