Right now I'm testing CPU @445x9=4005 and RAM @534/5-5-4-9 - all (sub)timings the same sa given few posts above
Everest memory performance looks like this
http://img409.imageshack.us/img409/4618/x382xy0.jpg
i took out my mushkins with d9gkx to test out a pair of kingston value d9ghm
2.2v
i finally broke 11000 lol
with a little tweakin should get better
my new 24/7:D
cpu 1.54v
vdmm 2.1v
woot nice one zsamz_
zamz nice work, is that your normal 4 gmh sticks but with performance lvl 7 and whats the NB voltage and phase settings still eaeee eaaee
I was looking in the DFI manual and it said that PCIE 1, 3 and 4 are all x16. I'm wondering if there would be an impact on performance if I run my single GPU in slot 4? In case anyone is wondering why, my OCZ xtc ram cooler won't fit with the GPU in slot 1 and my SB waterblock blocks slot 3.
slot 4 is a 4x electrical pci-e1 slot so i wouldent use it for grafix, but slot 3 works great
and u dont need a water block on the SB it barely needs a heat sink
no bud its my crappy kingston value pc2-667 lol "d9gmh"
i had to go performance level 8 @ 535fsb lol but phase settings are eaeee
i got another pair in my hr-07s:D
my 2 sets of ballistix 8500 been put away for a rainy day
i put my mushkins that couldnt go past 1155 with 2.32v into my old p35 now they doin 1200+ with 2.22v
i wasnt happy with those d9gkx but my son lovin em now
since i broke 11000mbs my next goal is to break 12000mbs:D
takin a break soon i will see how high i can go lol gonna try 2.32v next
now i really cant wait for my block to arrive so i can flash to the x48 bios on a new block and keep my original intact
man i thought you had it already biosdepot is quick n cheap
took 5 days for me to get mine i'm in canada :rofl:
i paid 24$ for 2 chips shipped:D
i miss the days when it way 5$ for a damn chip
my sons pc was @ 8500mbs:rofl: now he happy with 10200:p:
New BIOS for the 'bold' ones:
http://www.dfi.com.tw/Support/Downlo...FLAG=A&SITE=US
If you flash it to x48,can you flash it to x38 again?
Anyone tried to flash a x38 to x48 with the 03/20 bios? Results?
Yes, zsamz did:
http://www.xtremesystems.org/forums/...postcount=2531
It's still working. X48 is just a binned X38.
So did felix bg:
http://www.xtremesystems.org/forums/...postcount=2536
Ah sweet, might flash aswell.
Btw http://img90.imageshack.us/img90/3228/mem1254rk2.jpg
Was able to boot up at 1300MHz, but as soon as windows started to load, BSOD ruined the fun =/
2,38v is at the edge of doable for me, 2,4 > is quite risky.
I'm not that familiar with the GTL settings. How's the impact of increasing/decreasing them? When is it effective to increase/decrease them?
so did i, and proof that itÄs the same thing is
a) the flash works
b) the bios says x38/x48 series on the logon screen, so they dont even differ between x38/x48
Performance increase with X48 bios i'd say is wishful thinking....or as eva2000 said probably because NB voltage-table glitch is still in the bios, resulting in dangerously high NB voltages for all "made in china" boards selecting certain NB voltages, resulting in better stability at tighter timings (yeah, running NB at 1.76V, much luck with that :)
I personally dont think the X48 bios is worth it:
a) old bugs are sitll in there (still resetting to default cmos values with 8x multi and certain straps on otherwise stable settings)
b) dangerous NB voltages bug might kill china boards
c) no real performance increase (IMHO)
Yeah, I know. Can you put a fan on the H/L series. I know the singles cost more, but you can mount a fan easily and it has more surface area to cool. I haven't seen any reviews to see witch is better and the cost is only about $4 higher. I'm only planing on running 2 sticks anyway. Maybe I'll just flip a coin, lol.
