so what happens if you get ln2 ;) nice run man.
Im in stage 1 again and almost done with the pcv bench. im on communications 2 test. cross your fingers. brb. i need to get over there and pour some more juice.
***5380
http://hwbot.org/competition/hoc_nov10
http://hwbot.org/community/submission/1079411_
@Linuxfan how did you score that Rampage Extreme x48?!!!
You are holding a piece of 775 history.. its by far one of the best motherboards ever made.
dont kill it please. when you are done with your session unplug everything and take the container off and let it air out. maybe put grease in the socket and dimms just to be safe. take every precaution and treat it with dignity and respect. its worth more than its weight in gold.
its without question the best 775 board you can have! :toast:
my ln2 1st stage run ended prematurely due to condensation. the board should be good but I just need to air it out.
all of you in the nov contest on pcmV. There is some brazilian dude in 1st in the 2 core challenge with around 16k.
http://hwbot.org/community/submissio...5k_16390_marks
I was up to 5. ghz on the max3F on 660 and lsi 9260 x 3x 50gb v2 and a 5770 and was getting around 9k. then I found out he had every suite checked. not just the 1st one like weve all been doing. he checked every bench in pcV. maybe this is the secret? Im gonna do a test. Im gonna run the 1st ste on my 4 core rig and then run everything and compare scores. a 20 min bench compared to a 60 min bench. lets see if its worth 60 min of ln2 at once. brb
