The problem is the same.Pictures in the game just stops but no BSOD and I have to reset the computer. This happens after 15min, but only in the game BBC2. In other games, everything is ok ( Dead Space2,...). Any idea what could be wrong?
I have the latest driver for video card 266.58. This can be a problem for graphic drivers?
CPU: Intel® Core™ i7 980x 4.5Ghz (water cooling with EK HF)
MB: EVGA Classified X58
RAM: CORSAIR DOMINATOR GT 3X2GB 2000Mhz
GPU: eVGA GTX 580 (water cooling with EK-FC580 GTX - Nickel)
SSD: 2x OCZ Vertex 2 120gb Raid0
HDD: 2x Samsung F3 HD103SJ
PSU: Enermax Revolution85+ 1250W
CASE: Corsair Obsidian 800D | G19 & G9 | Acer S243HL | Z-5500 |
it can be
cause its doing it with only 1 game
still weird
and post full bios template not picture
Code:AIN
CPU clock ratio -
BCLK -
MCH strap -
Uncore -
CPU clock skew -
Spread spectrum -
PCI-E freq -
OC recovery -
Turbo Performance -
CPU features
SpeedStep -
Turbo -
C*E -
executive disable bit -
VT -
HT -
Core number -
QPI control settings -
QPI link fast mode -
QPI frequency -
Memory features
Memory frequency -
CH interleave
RK interleave -
Mem low gap -
CL -
tRCD -
tRP -
tRAS -
tRFC -
Command rate -
tRRD -
tFAW -
tRPT -
tWR -
RTL 1 -
RTL 2 -
RTL 3 -
tsrWrTRd -
Voltage features
Vdroop control - without vdroop
VCORE -
VTT -
CPU PLL -
IOH PLL -
QPI PLL -
VDIMM -
DIMM ref -
IOH core -
IOH/ICH/ I/O voltage -
ICH core -
VTT PWM freq -
CPU PWM freq -
CPU impedance -
QPI signal comp -
how do I do? Do I have to write the voltage?
This si my settings
AIN
CPU clock ratio - 31
BCLK - 146
MCH strap - 2133Mhz
Uncore - 2634(18X)
CPU clock skew - 0ps
Spread spectrum - disabled
PCI-E freq - 100
OC recovery - disabled
Turbo Performance - disabled
CPU features
SpeedStep - disabled
Turbo - enabled
C*E - disabled
executive disable bit - disabled
VT - disabled
HT - enabled
Core number - all
QPI control settings - enabled
QPI link fast mode - enabled
QPI frequency - 6.400gt/s
Memory features
Memory frequency - 1600/ 2:12
CH interleave - 6way
RK interleave - 4way
Mem low gap - auto
CL - 8
tRCD - 8
tRP - 8
tRAS - 24
tRFC - 72
Command rate - 1T
tRRD - auto
tFAW - auto
tRPT - auto
tWR - auto
RTL 1 - auto
RTL 2 - auto
RTL 3 - auto
tsrWrTRd - auto
Voltage features
VCORE - 1.4125V
VTT - +150mV
CPU PLL - 1.65
IOH PLL - 1.80
QPI PLL - 1.35
VDIMM - 1.65
DIMM ref - 0mV
IOH core - 1.25
IOH/ICH/ I/O voltage - 1.55
ICH core - 1.10
VTT PWM freq - 610KHz
CPU PWM freq - 1333KHz
CPU impedance - Less
QPI signal comp - Less
MTM
VTT PWM freq - 610KHz lower to 250
CPU PWM freq - 1333KHz lower to 840
PCI-E freq - 100 set to 101
MCH strap - 2133Mhz lower to 1600
Uncore - 2634(18X) set to 2400(17x)
CPU PWM freq - 1333KHz I make 940 because it is at least.
Uncore - 2634(18X) this is at least.
LinX after two minutes shows error with these settings!
I do not know why it does not work prim95?
you have bios 77 on?
i have bios version 78
Try silver conductive pen? It's very easy and reliable...
I wonder what's the difference between the 970 and a 980x in the eyes of the board? My e762 runs fine with the 980x, but with a 920, it won't run any ram at 2000Mhz, even at loose timings. Its been driving me insane. Using bios 78.Quote:
have you figured this out?i just got a 970 and my E760 does the same,no x25 yet?
not all CPU have good IMC, you can't put all the blame on the mobo
@mk-ultra: not that I am blaming the board. I just find it interesting as that 920 works on other boards running 2000mhz ram. Even my e759 runs it better.
@zsamz: well, I did try. It just won't boot when the memory is running 2000Mhz or greater. All is good though. I dun plan in trying hard to find out what the problem is. I just used that 920 to flash to the 78 bios and thought of giving it a whirl before putting the 980x in. :)
Is 990x detected properly on latest E770 boards ?
