Ok So I won't loose any data?
I was thinking you must format an HDD to put it in an array of RAID 0...
That was it...thanks!! Now at Performance Level 7 with 8GB's @ 1066mhz. Nice...:D
So to do this change back and forth between Rampage and Maximus you now only do the steps that The Stilt described in the OP with the AFUDOS version that ZenEffect provided and everything is good and working?
If you have found a solution finally to revert plz do post it on first post
so as to be clear with all details. Thanx anyway!
Yeah be good if someone could post how to go back and forth between the two , as i am an AFUDOS noob
With AFUDOS 2.29ES running the .bat files is unneccessary.
Just use AFUDOS /ifilename.rom /pbnc /n
@ChaosMinionX i remembered the problem you had with dividers.
Are everything ok with 'rampage'?
anyone found bios 0219 yet ?
Not yet but Bios 214 is working good though. :)
Just use EZ-flash in bios and flash with 214 ?
well yeah..it seems that you only need to do this.
wow !! :shocked: great done mate :up:
Is this mod working with Maximus Extreme?????:confused:
And also the reverse is done with same engineering version?
everything is in place within seconds...
flashed, cleared Cmos and maximus becomes rampage ;)
back to the old days of PAT flashing boards...got to love it :)
Ahh this is simply fantastic! Thanks to everyone! This no longer being a 1 way street is great. Again, thanks to all you guys for all the research!
PL5 with 1.5Vmch eeeeeeeasy...
same here up and running with 1 command thanks
now back to prime
