What a crock. TM2 isn't even enabled by default and when it is, it only kicks in when the processor reaches a critical temp.
If you're up to a challenge, you can respond with something like...
According to the document "Intel® Core™2 Duo Desktop Processor E6000∆ and E4000∆ Sequence Thermal and Mechanical Design Guidelines", TM2 is disabled by default and when it is enabled, it only becomes active when
the processor reaches a critical temperature. Further, it appears that the 975XBX2 BIOS does NOT enable TM2 although the same document states that it is required.
The document is at
http://www.intel.com/design/core2duo/documentation.htm
