Ehhhh.... 1.31V only at 2.85 Ghz is not bad. And when did 50C load become a problem? Your ship is made to handle 64C max if I'm not mistaken. :rolleyes:Quote:
You should know that higher temps lead to instability right? And the higher the frequency you run, the more temp-dependent you become. So while at stock speeds you might be able to run at 64c, if i were priming at 3 Ghz and somehow the temp got to 64c, it would immiately crash i am sure, or at least error out of every major app running.
Makes sense, but why 50C and not 45 or 55...still headroom there.Quote:
Absolute_0, the voltages you indicate are from cpu-z.
Could you indicate what voltages were used in the bios? :)
Sure
1.312 = default votlage settings
1.360 = 1.35 + 104%
1.408 = 1.40 + 104%
1.424 = 1.425 + 104%
1.452 = 1.450 + 104%
1.488 = 1.475 + 104%
if you meant what the bios says for voltage, then, it's usually just a little bit more than what CPUZ says.
ebay - 170 0550 vpmw - 625$:eek:
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=6852204758
Is that expensive? That's roughly how much they are from eStores here in the UK. . .Quote:
and I have another one on eBay right now.
I dont set the price, eBayers do.
Absolute_0, I could do 3gighz no problem, but I had to keep it cool, it hated 50C with a passion. When it was below 0C out, my big typhoon had no problems keeping the temps at 45 or lower. I went topless, and that didnt help as much as I thought it would. They are definitely just HOT CPU's.
I run daily at 2900mhz on air, it is a sweet chip. Too bad I am going yonah... gotta wait for motherboards to come out.
Im sure if I had a nice water setup, I could pump 1.65vcore and hit 3200+ I have no problems booting at 3200... just core0 isnt stable.
Burning in helped a LOT for me. Just make sure you burn in both cores at the same time. CPU burn core0 on normal, prime95 core1 is what I did.
good business:clap: grat:)Quote:
Originally Posted by irev210
Yeah you know what, that's exactly what i started doing. Core0 kept erroring out while core1 kept going, so i left core1 running SP2004 and i opened up CPU Burn in and set it to core0 and let that run.
Seems like a good idea. I'll try to keep her burning. Watercooling is finally assembled too ;)
yup... that is the way to do it. I did it for about a week, every night I would just let it run.
what are you hoping to do get core0 to work at 3.o ghz..so are you running cpu burn on core0 at 3ghz and prime 95 on core1Quote:
Well i was burning in, now i am watercooling and 3 Ghz is easily stable with less volts
I dont know why temps are so bad, but this is on watercooling, and on air i needed 1.48volts, now 1.42v to run 3.0 Ghz dual sp2004
http://img.photobucket.com/albums/v7...l/2a4f0f5d.jpg
Pretty similar to Rufus' chip isn't it?
http://www.bilder-hosting.de/show/X3FOZ.html
man u guys are making me so jealous :p:
I was satisfied with 2.8Ghz, but now i want more, so many peeps hitting such sweet clocks. Just a few comments in this thread I found quite funny.
:p: dude, 1.31v, 2.8Ghz, not bad; not bad you say, man tht is amazing :slobber: Absolute_0 is on air-cooling. I really cant understand your commet abt it being not bad :p:. Oh and welcome to the forums :DQuote:
Originally Posted by betroz
Absolute_0 looking forward to the WC results, for sure the heat output is holding you back. Ofcourse your future results have to confirm this
Hey - watercooled results are the post above yours
Dont know why it was showing 46, performed like 43 or something, maybe temp sensor is Fd up.
Good job Absolute_0, nice to see the WC helped with the 3Ghz stability! Are you going to throw it under the phase in your sig?
Nope because CCB1E is gonna coldbug like crazy.
Absolute_0 ..what WC do you use?
I'm considering going water one of theese days, not as much for OC'ing as for getting that quiet working environment.
...a hefty OC will not hurt though ;)
doh, i should have made myself clear, i was talking abt the 165'sQuote:
:slap:
Do you think you can point out any difference between the 165's and 170 tht you think are quite relevant in terms of how they overclk?
Ok first of all my WC is in sig
MCP600/TDX/120.2 heatercore
As for overclocking on water versus air. Well my 170 needed 1.48v on air to do 3 Ghz now on water it's doing the same on 1.42.
On aircooling my 165s walled up around 2.9 Ghz so i'm guessing with watercooling and more volts they'd do 2.9+ maybe 2.95 if they were reaally pushed. I'll test them out later, too much funw ith the 170.
As for plain comparing 165 and 170, on the 170 the cores seem a little more balanced, on 165 core1 is insanely stronger, on 170 core1 is just a little stronger.
That's interesting?Quote:
How come the chip needs less voltage to run when on water compared to air?
Because the chip is slightly cooler = law of physics :DQuote:
Originally Posted by Big.Wayne
I am far from maxed out
http://img.photobucket.com/albums/v7...l/069afa45.jpg
me too :p:Quote:
