Finally, 130K+ with 4890 CF....This old UD7 B3 still got it:)
http://img31.imageshack.us/img31/588...enshot112n.jpg
excellent job dumo
GA-Z68X-UD7-B3 - F8c -07.Jul 11
GA-P67A-UD7-B3 - F5b -08.Jul 11
-Fix Intel Extreme Tuning Utility compatibility
GA-Z68X-UD7-B3 - F8c JZ -12.Jul 11
-Fix MultiStep Loadline
Btw,
All Z68,P67 beta BIOS official updated today.
yea dn excellent to see that LLC is made stronger on the UD7
Mem. bug F5b UD7 B3? Set up at 2133 from bios and stuck @ 1333 in windows
http://img219.imageshack.us/img219/3...nshot115cx.jpg
Same bios settings with F4...
http://img829.imageshack.us/img829/3...enshot116f.jpg
Maybe u can try F5d BIOS then~~~?
Do you have the link for F5d?
Seems that all new beta BIOS have same bug,except F8c JZ -12.Jul 11.
stasio
no intend to be rude with you but basically another useless bios from us P67A UD7 users ?
Sorry for the off topic, but the ones here with z68x-ud7 weren't capable of using the lucid virtu options isn't it?
I mean you cant't you at least lucid on D-MODE, isn't it?
Thanks!
The BIOS dated after July 8th will have mem bug so temporary stick to your current version. Don't update them now. BTW the website has removed them as well.
Osterman:
No VGA output on Z68X-UD7 so you wont be able to use Virtu.
thanks
so far giga util didnt work on that...
Which utilities?
Sergio,Dumo....I will upload new beta BIOS (July 13th) here,can you check and let me know?
.......GA-P67A-UD7-B3 - F5d
Edit:
I am lazy to go back to BIOS P67A.
Thanks,which utilities didn't work?
Oooo,they implementing TouchBIOS utility for P67. :clap:
I will inform GB about this.
OK,for BIOS,must wait for next week then (or maybe later today?).
It's same problem as for Z68 series,I have latest Beta but mem problem same.
Anyway thanks Sergio.
Edit:
It's mean only voltage part crash?
What about other parts?
here's where it crashes the other things are slow but goes ok, i took out ET6 just in case but same, mem problem persists...
http://img841.imageshack.us/img841/7459/capturamin.png
Uploaded with ImageShack.us
TouchBIOS ver.B11.0623 right?
OK,send your post to GBT.
Btw,
congrats for URUGUAY !!
yes
Product=TouchBIOS B11.0623.1
bios seems faster than F4, its a pity mem dont work, hope they also improve LLC levels im using LLC7 seems fine for now
Thanks we go against ARGENTINA on Saturday !!!
hope we have a fast update for me its mem divider probelm as i tested down and up and does the same
cheers mate !
Sergio
btw: how is Win8 working ?
OK.
Yeah,they fix LLC,implementing TouchBIOS,but mem bug.....will be OK next week (or earlier) sure.
ET6 shold work fine together with TB.
Only latest ver.B11.630.1 didn't show LLC levels (always in Default) for me.B11.512.1 is OK.
Fingers cross for you on Saturday..!!
Win 8 7989 a bit buggy,but not so bad.Waiting for first Beta.
