has anyboday used F5a yet?
F4a was very unstable, constant bsod 124
I can't believe that there has not been one decent bios released for this board yet, I am on F3h and it is ok but all of the bios need work imho.
do u guys use turbo boost when OC ? i never touched it its still enabled...
BIOS rule... the POST will display the highest clock configured in BIOS (including turbo ratio).
So far F4 been good to me:)
Imo, its all depend on how good your Sandy is
As long as bios boot at 100 BCLK and cpu's max multi then ramped up with easy tune to cpu max. mhz.
Reboots with C1 twice still happened often, but it will post windows after a few try
This went all night long:)
http://img835.imageshack.us/img835/3...enshot032c.jpg
Wow Dumo, and i thought that i had a high binned one.
Now try 8 threads and LinX with AVX :D I'am curious what you're chip does than.
I squeez't this out today, gonna do a 20 run for the linx stable club later.:D
http://i.imgur.com/jOdBkl.jpg
GA-Z68X-UD7-B3 - F7h
-Fix Touch BIOS
-16.Jun 11
CPU-Z 1.58 Beta
http://www.fileden.com/files/2010/4/...-32bits-en.zip
- AMD FX "Bulldozer" processors family.
- Intel Sandy Bridge-EP processors preliminary support.
Edit:
Still bug ,
show VTT voltage on Gigabyte Z68X-UD7 (maybe new BIOS?).
http://i7.aijaa.com/b/00304/8229568.png
http://i10.aijaa.com/b/00346/8229711.png
All Z68 series official BIOS updated.
CPU-Z 1.58
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.58-setup-en.exe
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.58-32bits-en.zip
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.58-64bits-en.zip
- AMD FX "Bulldozer" processors family (K15).
- AMD Llano processors family (K12).
This "forgotten" UD7 B3 stuck with F4 bios. Lol
Even with those new Z68 boards stole the limelight, its still going:)
http://img28.imageshack.us/img28/838...enshot099p.jpg
Have to dust off my old 4890 top...
http://img200.imageshack.us/img200/1...enshot043u.jpg
http://img594.imageshack.us/img594/7...enshot095c.jpg
One more run before gpu go cold...Gotta chase that E8600 @6.5Ghz!:)
http://img837.imageshack.us/img837/1...nshot104ff.jpg
Almost there, nice run.
Thanks Tom:)
Got it with CF
Next will be 1X 5870...chase that MIVE @ #1:)
http://img856.imageshack.us/img856/5...enshot108l.jpg
Thanks L_S
Probly maxed for this ram and so far 5850Mhz 4C/4T for this chip under SS....it won't run Vantage cpu and wprime 4C/8T @ max. wall though
More cold probly help, but I doubt it
Thanks kagula, its pure luck and quantity really help
Testing '05 4890 CF
No bios refresh, still F4, probly Giga can pull a MIVE ones...New P67 UD7-B3 bios specifically for '01:)
http://img840.imageshack.us/img840/5...enshot049a.jpg
Great score Dumo! GT1 and GT2 scores are awesome.
