Been busy lately, thnx alot for the info about LLC, wake up call for me :p: Hope everest helped u out :)
Would like to know if 1003 exist or is it some kind internal beta or typo.. ? :confused:
some present from Fire4Wire for you Guys
Bios 1003
http://www.megaupload.com/?d=RWS8DG6D
Thanks! :up: but we need something fresh. ;)
Bios 1004
http://www.megaupload.com/?d=U5X7COFX
Yeah, that's fresh. :up: EDIT: Well, maybe not so fresh, older then 0011, but a new toy to play with. :D
Now to see is it better or average. ;)
:up: thanks dude =) u is tha king :D
Hey, PytonOrm, did you manage to kill your 980X? ;)
And how about 1004 ? Any opinions :)
Yesterday, I tested some BIOS (0704/9124/1003/0011) under LN2.
I think "9124" is best BIOS under LN2.
It's very stable & good score than other BIOS.:)
(Unfortunately, My chip can not improved CBB & CB by "0704")
*3DMark06 - 40314
http://img844.imageshack.us/img844/4...0640314.th.jpg
you are tested the 1004?
No :D still lives its freaking sick cpu :eek: now with bios 1004 i got this
http://valid.canardpc.com/show_oc.php?id=1377123
:D
What do you use use to check temps?
Are there still issue with the microcode? and 3rd party temp viewers?
Realtemp and Coretemp for example?
Think 0009-0010 or around there had a fix to read temps more accurate, using Coretemp and Everest atm myself. Tried Realtemp and its pretty much to same as coretemp give or take 1 Celcius. Not 100% sure they really read it spot on, but i guess its not far from reality when temps get high :p:
@donmarkoni
Thnx for reply on 1003 and message with bios :)
@Fire4Wire
Thanks alot but i get "The file you are trying to access is temporarily unavailable." on both files :confused: Will try again later :)
Edit: Nvm got it sorted just had to click a couple times on reload page :p:
Hello Guys,
PC Spec's below.
980x, CMT6GX3M3A2000C8 x2 = 12GB RAM, Rampage III Extreme, Sapphire 5970 4GB, Enermax Rev85+ 1250w, 8x Pioneer Bluray writer, 24x Liteon DVD writer, OS: Crucial C300 256GB, Tier 1 storage: 2x Samsung F1 500GB, Tier 2 storage: 2x 1Tb Samsung F3, KillerNIC 2000 Pro - all housed in a windowed black TJ07 with 2x 92mm revoltec's, 3x 120mm sharkoon's at 700rpm, front HDD intake at 1200RPM. WCed by Aquaduct 720XT with Cuplex Kryos HF (all compression fittings) filled with black UV feser.
Using BIOS 0011 I have only managed to reach stable settings below.
Need it take the system higher...any advice please?
Code:
Target CPU Frequency 3918.9MHz
Target DRAM Frequency 1704MHz
LN2 Mode []***
QPI Loadline Calibration []***
Sync Mode [EN]
AI Overclock Tuner [MAN]
OC From CPU level Up [Auto]
CPU Ratio Setting [23]
CPU Turbo Power Limit [DIS]
>CPU Configuration----------------------------
C1E Support [DIS]
Hardware Prefetcher [EN]
Adjacent Cache Line Prefetcher [EN]
Intel(R) Virtualiyation Tech [EN]
CPU TM Function [EN]
Execute Disable Bit [EN]
Intel(R) HT Technology [EN]
Active Processor Cores [ALL]
A20M []
Intel(R) SpeedStep(TM) Tech [DIS]
Intel(R) C-STATE Tech []
C State package limit setting [DIS]
BCLK Frequency [170]
PCIE Frequency [100]
DRAM Frequency [DDR3-1704mhz]
UCLK Frequency [3238]
QPI Link Data Rate [Auto]
Memory Configuration Protect [DIS]
>DRAM Timing Control--------------------------
CAS# Latency [8]
RAS# to CAS# Delay [9]
RAS# PRE Time [8]
RAS# ACT Time [8]
RAS# to RAS# Delay [24]
REF Cycle Time []
WRITE Recovery Time []
READ to PRE Time []
FOUR ACT WIN Time []
Back-To-BackCAS# Delay []
Timing Mode [2N]
Round Trip Latency on CHA []
Round Trip Latency on CHB []
Round Trip Latency on CHC []
WRITE To READ Delay(DD) []
WRITE To READ Delay(DR) []
WRITE To READ Delay(SR) []
READ To WRITE Delay(DD) []
READ To WRITE Delay(DR) []
READ To WRITE Delay(SR) []
READ To READ Delay(DD) []
READ To READ Delay(DR) []
READ To READ Delay(SR) []
WRITE To WRITE Delay(DD) []
WRITE To WRITE Delay(DR) []
WRITE To WRITE Delay(SR) []
CPU Differential Amplitude [Auto]
CPU Clock Skew [Auto]
IOH Clock Skew [Auto]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode [T-balanced]
PWR Volt. Control [Auto]
Load-Line Calibration [Auto]
CPU Voltege OCP [EN]
CPU PWM Frequency [Auto]
Extreme OV [DIS]
Extreme OC [Auto]
CPU Voltage [1.25000]
CPU PLL Voltage [1.81525]
QPI/DRAM Core Voltage [1.35000]
DRAM Bus Voltage [1.64300]
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA []
DRAM CTRL REF Voltage on CHA []
DRAM DATA REF Voltage on CHB []
DRAM CTRL REF Voltage on CHB []
DRAM DATA REF Voltage on CHC []
DRAM CTRL REF Voltage on CHC []
IOH Voltage [1.11300]
IOH PCIE Voltage [1.81050]
ICH Voltage [1.11300]
ICH PCIE Voltage [1.51050]
---------- Spread Spectrum Control -----------
CPU Spread Spectrum [DIS]
DRAM Spread Spectrum [DIS]
***on-board jumper dependant
kyle...the uncore is fine
er...cool...can u give me a mini lesson on what it should be please?
My mistake, I did not originally notice that you had a 980x, in that case, scratch that. You may want to try disabling Intel VT. How specifically are you crashing? During POST, stress testing, are you receiving a BSOD, or just hard locking? You may also wish to enable QPI LLC with the jumper on board (even 1.55v VTT did not accomplish stability, but this setting w/ 1.4v managed to.) , as that, coupled with upping PCIe freq + disabling VT got me from 4.2GHz - 4.6GHz stable with this board on an i7 930.
kyle...np. At the settings posted the PC is totally stable, I am happy with the stability with no issues. My problem is pushing the system further. I have go from 1.25vcore to 1.29v to get 4Ghz and even then its not 100% stable. Need some hints in how to OC this mobo more effectively. I need VT enabled.
Asus ROG connect just stopped working!
There is no bios settings for that?
Just the button on the back right?
Stopped on bluetooth too!
