@greg.m, what's your max prime95 blend & linpack (linx/ibt) stable configuration, because if it is 9x480 you should be happy and not to think to change your board.
Here you can see my 20 pass linx:http://www.xtremesystems.org/forums/...postcount=2495
I havent blendprimed with these settings but i will and see what happens.
My opinion on the DDR 1200MHz issue is that once on an Advert and not possible to be reached by the community (us), Each one of us needs to raise a ticket and needs to be marked to Asus with subject Escalate the problem..
Dude, they are gonna use the same lame a$$ excuse of not "supporting" overclocking.... It's pretty much a moot point, till someone can "mod" or fix the current bios's.... Asus just doesnt give a frak......
Its not what you say but how you say it.
Yoh guys,
I donīt feel anymore like waiting for the ASUS-break-down-bios. Guess what I did?
You are right- :yepp:I just ordered a DFI DK P45-T2 RS Plus.
This board is supposed to make a fsb of 500 MHz possible. The memory oc over 12xx MHz will be possible too. As soon as I have this board I will tell you about it.
how about that?
DDR2-1250 MHz capability
A* B* C*
1024MB CORSAIR Heat-Sink Package N/A DS N/A V
DDR2-1200 MHz capability
A* B* C*
512MB KINGSTON KHX9600D2/512 N/A SS N/A V
1024MB KINGSTON KHX9600D2/1G N/A DS N/A V
1024MB OCZ Heat-Sink Package N/A DS N/A V
http://images.google.com/imgres?imgu...a%3DN%26um%3D1
is this of interest?
hi all, this is my first post so I'm technically a newbie!!! other than that I overclock the hell out of my rig. My experience with bios 0902 is so far so good. I can't complain about it as my baby's stable at 465x9 (558 MHz on memory). I did some burnin' test:
http://img.techpowerup.org/090519/mybaby276.jpg
~talk to ya later
Looking good, nice work :up:
Have you done any P95 blend with max mem use yet?
Because 266 do not use fsb strap divisor 4:5??? Help plizzzz
@ Greg. I been doing 8x450 with mem 5-5-5-15-40 Stable :)
But the 8x455 Mem 5-5-5-18-55 8x460 mem 5-5-5-18-55 failing at large FFTs over if NB is higher.(around 8th pass or so)'
But iam quite sure that my CPU QX6700 is at its limits LinX for example with shut down the PC around the 5th pass.
The Gigabyte UD3R has a P45 chip too. So I donīt know if there is a big difference between these boards.
Whatever, I canīt wait to see my G.Skills going up to 1300 MHz or maybe more.
ASUS wonīt disappoint me anymore!
I appreciate mikeyakameīs recommandation. Thank you very much:clap::clap::clap:
P.S. Is nonetheless the very same like nevertheless? Seems to be american English?
with which clocks-settings do you mean? Btw i found out that the skew combo that is the most stable for me is normal/normal. Everything else gives me errors(memory) almost right from the beggining and ive tried:
cpuskew: normal(best), 100 , 100, 200, 200, 300
nbskew : normal(best), normal, 100, 100, 200, 200
With 9 X 465MHz and DDR 1117MHz tRD 7. When Chemjsal can get that stable with 8 Giga you should have no problem to have it IntelBurnTest stable with the G.SKILL F2-9600CL5D-4GBPI.
When you can't get that stable and I can get it stable with 8 X 465MHz it must be a compatibility between the memory and the board.
Try with advancing the DRAM CLK Skew on Channel A and B with 100ps to if you can keep your memory more stable.
@A-grey. I'm using 4x2 Giga :D G.Skill PC2-8800. I've used 4x1 GB Team Xtreem TXDD2048M800HC3DC before. My best ride @1239 MHz (2.30V) at PL6 with all four sticks. Unfortunately, the memory's not fully compatible with the board as it's a general pain in the ass to get it up and running so I switched to G.Skill. The other reason for the switch was the fact that I use Mac OS X Leopard (10.5.7, two WD360ADFD raptors in RAID0 on Areca ARC-1210) as my main operating system and so 8 giga comes in handy. Anyway, I love this mobo.
____________________
Rampage Formula @0902, 4x2 GB G.Skill PC2-8800 (5-5-5-15, 2T) at 1.90V (PL7), Q9650 ES@4.19 GHz at 1.4125V (1.38V real, 1.30V load) on water, LLC disabled!, Asus 4870 TOP 512MB @880/1180 MHz on water, Dell 2405 FPW, Lian-Li PC-V2000 black
will do
