Mad MikeE burn-in/testing recipe
There ARE other dividers, use one of them.
Use my example and plug in other dividers to get the 'multi' that works best for you :D (math is left as excercise for the student :fact: )
You need to know what you memory can do so you are only testing 1 variable. I know my TCCD will go to 300 easily (2.67Vdimm)
We are testing/burning in the ALL the CPU, including the memctlr here. Pick your multi/divider and set yourself up lower and work your way up, will help more in the long run :D
1. Go back and find your max dual prime stable (1024-4096K FFT, 1/2 available mem each (check in task manager)) @ DEFAULT Vcore (find the vcore measure point and get a dmm to find REAL VCORE and set to 1.35 (mine is 1.2something :cool: ) This is optional)
Find point that it runs for 8 hours w/o dying. I'm not doing the affinity thing, just running 2 instances, loads the CPU 100% and works w/ the OS instead of fighting it.
2. Move up 2 HTT after you get there and try again, repeating same cycle. Restart it if it dies, same settings, give it 3 times.
3. If it still dies, S&M 1.7.6 looping through all tests except power 1 (look @ settings, forget the first checkbox, #2 will test the CPU even More) & memory. Run that for 8 hrs, then try 2. again.
4. If you still fail 2, you can:
A) Loop through 3. & 2. a few times to burnin some more and it may work?
B) Knock Vcore up 1 notch and back to 2.
Stop when you are happy or Vcore and / or temps become an issue.
This is what I am doing. Hope it helps. I am in Step 3 @ 280x10 @ default (DMM) vcore on my 170 VPMW.
5. (Highly Desired): PM admin in list below to REALLY test your CPU in Rosetta under XS_THE_MACHINE :D
Originally Posted by K.I.T.T.
I get ya buddy, but having BH-5 makes it near impossible. The maximum it'll do is about 263 MHz stable. Still, IMO 2808 MHz is hardly shabby. So you think i should still burn in to lower volts? If so, do i start burn-in at 1.42v, or lower it first, if you get what i mean?
thanks buddy :)
I you had googled what I put down
You wold have gotten this:cool:
Originally Posted by Supertim0r
S&M link ?
