^^ Been using it for the past few days. Not bad. I was finally able to get my E8400 to 4.0GHz by having to adjust some of the GTL values.
anybody notice on the newer bios' the memory copy performance has gone down while read write and latency got better?
No not noticed as I dont flash beta's incase I have any problems with the board and have to RMA it, they are not obliged to repair / change your board for you if you have a beta bios on it, however all i can say to the change in memory performance is "its about bloody time" cos mem performance on this board at the moment sucks, but i'll wait for the official release.
the memory performance of the board is not that bad, not as good as my maximus but still not bad at all. you just gotta know how to tweak it. the tref is set rather to a mild 3120T, bumping it up via memset to 14592T will reduce your latency and up your read. i would re-check your stability afterwards. plus figuring out what all the values for your memory is important because some settings can be tightened up as well. for example my ram sets my trtp to 7 however it can run it stably at 3. this gave me more read and lower latency as well.
Just for you ZenEffect, I can get the tRFC down to 48 and although its passed memtest at 48, it doesnt feel stable, I have a few strange going on's, my trtp is at 5, which the default is 8, cant seem to tighten that up anymore either, not too sure where I adjust the tREF in the bios but my mem timmings including subs have been pretty much tightened up to what they will do and what feels stable and what passes memtest to my satisfaction. My ram is rated 5-5-5-18 at 1150mhz but is doing 1128mhz at 5-5-5-15 (limited by CPU speed), might be able to get the 15 to 12, but to be honest im really not going to see that much of a performance boost for hours more of testing, is it really worth it.
its not so much the read that concerns me, its the write and the copy which are so far behind, infact so far behind they are almost at stock speeds of most other boards, my ASUS P5Q-e P45 used to run all 3 (read, write and copy) closer to the 10k mark, but I hated that board, moved to crossfire and brought a decent board.
2x2GB on the UT X48 board.
click for larger image
http://www.edgeofstability.com/image...erest_64_s.jpg
Nice Praz, what RAM is that, please dont say OCZ Flex 2 as I noticed its running 1152mhz, if it is then tell me what im doing wrong, or if its got anything to do with the wolfie that your running ?
Those speeds you have there are more like what I was getting out of the ASUS board, just cant seem to find nor get them on this one, this is what im doing right now, and its definatly not good.
Yeah it's Flex 2. The settings are posted in the following link. Posts 11, 12 and 13.
http://csd.dficlub.org/forum/showthr...?t=6689&page=2
praz good work man, this is faster than i was at 500x9 i think, gonan use this as a template when i get my new psu
Im still not even close to this with your setting set in the bios, I think somewhere, somehow, the CPu you dividers etc your using Praz play a big part in this, I remembered earlier that when I was scoring high on my P45, it was with an e8400 at 4.2ghz, but that eventually degraded and died on me, I might pick another up in a couple of days a put this too the test, cos I was forced to move back to my Q6600 which in fact feels slower than my E8400. :ROTF:
Thanks guys. I don't have any settings saved with a quad in the board. It's been so long I don't remember if the times were close to these or not.
Question for everyone.
I currently got 8GB DDR2-8000 (500FSB 1:1) stable, but with a NB of 1.65. Any recommendations to lower this, while keeping the system stable?
55c is were i drew the line with air cooling, with liquid its a bit harder since it stays cold as what to call max voltage, and depending on how hot the NB is running voltage can become counter productive
I am trying to get my PC stable with my Q6600 @ 3.6 (450 x 8), and ram @ 1128mhz 5-5-5-15-2T.
I bought this cpu 2nd hand because it can do 3.6ghz (450 x 8) @ 1.3375 vcore, 100.23% special add, vdroop: disabled; in a DFI X48 UT. I have had my ram at 1175mhz @ 5-5-5-15-2T before, but I have having problems getting them stable together.
With the current settings below, it will last 1 minute on OCCT before the PC locks up. The max temperature any CPU core reached was 63C. My chipset temps are fine. The AS5 still need time to cure and my water cooling loop still needs to settle, so I think temps will reduce over time.
My Specs:
Mobo: DFI LP X48 LT T2R | Bios 08/29 | XSPC Delta Chipset
CPU: Intel Q6600 G0 | Swiftech GTZ
Ram: OCZ PC2-9200 4GB (2 x 2GB) Flex II
GC: Asus 8800GT 512mb | Glacier Fan @ 700/1750/2000
SC: X-Fi Xtreme Gamer Fatal1ty Professional
HD's: WD 150GB Raptor & 4 x 250GB WD SE16 (Raid 0) & Seagate 7200.11 1TB
Optical Drives: 2 x NEC DVD Writers
PSU: SilverPower 600w
Case: NZXT Tempest
Cooling: Custom Water Cooling
OS: Windows XP Professional SP3
Bios Settings:
Code:CPU Feature
- Thermal Management Control: Disabled
- PPM(EIST) Mode: Disabled
- Limit CPUID MaxVal: Disabled
- CIE Function: Disabled
- Execute Disable Bit: Disabled
- Virtualization Technology: Disabled
- Core Multi-Processing: Enabled
Exist Setup Shutdown: Mode 2
Shutdown after AC Loss: Disabled
CLOCK VC0 divider: AUTO
CPU Clock Ratio Unlock
CPU Clock Ratio: 8x
- Target CPU Clock: 3600
CPU Clock: 450
Boot Up Clock: AUTO
DRAM Speed: 266/667
- Target DRAM Speed: 1128
PCIE Clock: 100mhz
PCIE Slot Config: 1X 1X
CPU Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
Voltage Settings
CPU VID Control: 1.3375v
CPU VID Special Add Limit: Enabled
CPU VID Special Add: 100.23%
DRAM Voltage Control: 2.12v
SB Core/CPU PLL Voltage: 1.510v
NB Core Voltage: 1.555v
CPU VTT Voltage: 1.310v
Vcore Droop Control: Disabled
Clockgen Voltage Control: 3.45v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: Disable
x CPU GTL1/3 REF Volt: 113 (Greyed Out)
x CPU GTL 0/2 REF Volt: 100 (Greyed Out)
x North Bridge GTL REF Volt: 100 (Greyed Out)
DRAM Timing
- Enhance Data transmitting: FAST
- Enhance Addressing: FAST
- T2 Dispatch: Auto
Clock Setting Fine Delay
DRAM CLK Driving Strength: Level 6
DRAM Data Driving Strength: Level 8
Ch1 DLL Default Skew Model: Model 0
Ch2 DLL Default Skew Model: Model 0
Fine Delay Step Degree: 5ps
Ch1 Clock Crossing Setting: Auto
- DIMM 1 Clock fine delay: Current
- DIMM 2 Clock fine delay: Current
- DIMM 1 Control fine delay: Current
- DIMM 2 Control fine delay: Current
- Ch 1 Command fine delay: Current
Ch2 Clock Crossing Setting: Auto
- DIMM 3 Clock fine delay: Current
- DIMM 4 Clock fine delay: Current
- DIMM 3 Control fine delay: Current
- DIMM 4 Control fine delay: Current
- Ch 2 Command fine delay: Current
Ch1Ch2 CommonClock Setting: Auto
Ch1 RDCAS GNT-Chip Delay: Auto
Ch1 WRCAS GNT-Chip Delay: Auto
Ch1 Command to CS Delay: Auto
Ch2 RDCAS GNT-Chip Delay: Auto
Ch2 WRCAS GNT-Chip Delay: Auto
Ch2 Command to CS Delay: Auto
CAS Latency Time (tCL): 5
RAS# to CAS# Delay (tRCD): 5
RAS# Precharge (tRP): 5
Precharge Delay (tRAS): 15
All Precharge to Act: 6
REF to ACT Delay (tRFC): 52
Performance LVL (Read Delay) (tRD): 7
Read delay phase adjust: Enter
Ch1 Read delay phase (4~0)
- Channel 1 Phase 0 Pull-In: AUTO (7)
- Channel 1 Phase 1 Pull-In: AUTO (7)
- Channel 1 Phase 2 Pull-In: AUTO (7)
- Channel 1 Phase 3 Pull-In: AUTO (7)
- Channel 1 Phase 4 Pull-In: AUTO (7)
Ch2 Read delay phase (4~0)
- Channel 2 Phase 0 Pull-In: Auto (7)
- Channel 2 Phase 1 Pull-In: Auto (7)
- Channel 2 Phase 2 Pull-In: Auto (7)
- Channel 2 Phase 3 Pull-In: Auto (7)
- Channel 2 Phase 4 Pull-In: Auto (7)
MCH ODT Latency: 1
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Read to Write Delay (tRDWR): AUTO
Ranks Write to Write (tWRWR): AUTO
Ranks Read to Read (tRDRD): AUTO
Ranks Write to Read (tWRRD): AUTO
Read CAS# Precharge (tRTP): AUTO
ALL PRE to Refresh: AUTO
These settings:
popped up when I updated the bios to 08/29 and I have no idea what to set them at (I never changed them) and how they effect the overclock.
Please can you help, I would love to get my PC stable at these speeds!
@!TIMMY!: why do you need to set your Special Add? try disabling it...
Well you system is pretty much exactly the same as mine, except for the sound card and the optical drives etc, you main hardware is exactly the same, CPU, RAM, Mobo, and for that, so are you settings except, you CPU vcore, if your CPU can trully do 3.6ghz then I would be very supprised if it can do that on stock voltages, if it can do that on stock voltages then you pretty much have a 4ghz'er there, I would start by raising you vcore if you are getting lock-up's, something isnt getting enough.
Anyone know where I can grab the latest beta bios from as a Diamond Flash utility for the LT board ?
It seems they only have the standand bin file in the beta section.
