Originally Posted by
[XC] 4X4N
I can get 3.6 with 1.3v, but 3.8 takes 1.4v, so I'm betting that you need more vcore. I've had quite a few quads, and getting above 3.6 is not easy. They scale pretty good up to 3.6, but from there most need a lot of voltage and put out a ton of heat. Even if you are lucky enough to get above 3.6 with low voltage, it's still hard to keep the temps reasonable with air cooling. Once summer hits and my ambient goes up to 80-85f, I'll have to clock it down.
Here are my voltages:
Cpu Voltage = 1.4
Cpu Voltage Reference =Auto
Cpu Voltage Damper = Enabled
Cpu PLL Voltage = 1.5
Dram Voltage = 1.95
FSB Term Voltage = 1.3
N.B. Voltage = 1.4
N.B. Voltage Reference = Auto
S.B. Voltage Reference = Auto
