Can I get any more powerrrrrrrrrrrr?
Hi guys, yet another fresh faced addition to the growing crowd of BX2 owners. :cool:
I'm wondering if I can get some advice. I've just put the rig below together and this is my first overclocking project since I overclocked a 300A Celeron to 450mhz back in the golden days of overclocking.
Right now the rig seems to be walled at 350mhz FSB. I've managed to overclock the memory bus to 266/667 for a healthy overclock of its own, but even with a 1:1 divider I can't seem to get any more out of this E6600 than 3.15 ghz. When I try to go to 366mhz I get a BIOS POST error (watchdog is disabled) and if I give a little more voltage to the FSB/vcore/etc then it will boot but starts to fail Prime95 testing.
At 9X350 the rig is a rock with all the default voltages. I was even able to confidently install the OS at this overclock since the system can run Orthos, etc, for 8+ hours at these speeds and be totally stable.
Does anyone have any ideas for squeezing a bit more juice out based on my settings below? CPU temps are idling around 38C and peaking at 62C according to TAT. It surprises me that the temps are as high as they are, the Zalman 9700NT is supposed to be a well regarded cooler.
Components;
E6600 (week 36 A stepping)
BX2
Corsair HX520W PSU
OCZ PC8500 5-5-5-15 2X1GB RAM (a real letdown, won't even run stable at 500 mhz with these timings)
EVGA 8800 GTS OC
Gigabyte Poseidon Case
2X Seagate 250GB 32MB Barricudas in an L1 RAID
Some screenshots of my BIOS settings below, if I'm missing something obvious let me know, I'm happy with what I'm getting out of it now, and don't want much higher temps, but when I bought the parts I was hoping for a healthy 9X400 overclock.
Thanks!!! :toast:
http://www.pagefamily.net/gallery/d/2880-1/IMG_5548.jpg
http://www.pagefamily.net/gallery/d/2880-1/IMG_5549.jpg
http://www.pagefamily.net/gallery/d/2880-1/IMG_5554.jpg
http://www.pagefamily.net/gallery/d/2880-1/IMG_5551.jpg
http://www.pagefamily.net/gallery/d/2880-1/IMG_5552.jpg
http://www.pagefamily.net/gallery/d/2880-1/IMG_5553.jpg
RAM Recommendation (run DDR800 on 400 FSB)
I had been running my E6300 @ 2.8 ghz (7 * 400 FSB). I'm running all voltages at their lowest 1.2, 1.5 and 1.2875 CPU. All is pretty good.
I have been running Corsair Dominator 8500s (1066 mhz 5-5-5-15 rated 2.2v). I had RAM set at 3-3-3-8, 2.16v, 266/533, which seemed to produce DDR800 speeds. It was fast and nice. Now, the system will not boot regardless of settings. I get 3 beeps (RAM error).
Fortunately, I have 1GB cheapo RAM which I am running temporarily. I'd like to buy 2 GB new RAM which can run at 266/533 (DDR800 at my FSB). I'm really looking for something that's going to be reliable and not too expensive. I don't want anything from Corsair.
I found these for $165 after rebate. However, I'd really like to get a brand/model that's been working for someone else with my configuration.
http://www.newegg.com/Product/Produc...82E16820220144
Any recommendations?
Mark
