My vpmw likes less voltage every day :toast:
http://img53.imageshack.us/img53/4879/3ghz12h0nt.th.jpg
This is the first chip that is folowing the rules of burning-in :D. At start the minimal voltage for 3GHz was 1.52V - now only 1.46V :woot:
Does anyone know how high HTT will an A8N32-SLI go? (in average, of course) I'm torn between A8N32-SLI and DFI Expert, and I need to get a board by the end of the week, which means I should order this morning (umm... like in 6 hours) so that I can do 2-day shipping by Friday.
What matters is OC-ability, and the OC-ability ONLY. :D I'm not interested in feature set or anything. Just better OC'ing and high HTT (my 165 needs more than 333 HTT). Since I'm on air, both boards supply sufficient Vcore, I guess. I've read A8N32 supports up to 1.6V for dual-core CPUs, which is more than enough for air-cooling. (or even water, probably)
If A8N32 can do 350+ HTT comfortably, I will probably go for it, since I like the 8-phase power and low noise. I've also heard with same vcore A8N32 will allow higher (albeit tiny) OC. It's also less picky on RAMs, etc.
But all the goods are no good if it can't guarantee 330+ HTT. In that case, I will go with the Expert.
Any input will be appreciated. Thanks in advance.
lop
offtopic / srry
http://img108.imageshack.us/img108/3866/vista0bk.jpg
@lopri
i tested mine to do 400htt - no problem wahtsoever .. and yes, max vcore for dual optys is 1.6, but i wouldn't go with mine over 1.55V ..
Thanks I was wondering just how much voltage to put through my opty during testing ;)Quote:
Originally Posted by no_n|ck
So far I have only tried 1.55v and I'm not game to try higher on air cooling
1. You have a 180 (9/10th divider) - USE IT! to get 10x multi :D
Start @ 10x275, get that working, then march up however far you can.
Only way to w/ deal temps - 'OFF WITH IT'S HEAD' etc. (Though I haven't had time to do my 'prep work' on this one yet )
Also check you vcore w/ DMM, mine = 1.4 @ bios = 1.35, so reset mine to 1.275x1.04 (works for me 1.33-1.36 under load DMM )
Running DC prime (large FFTs, use s&m 1.7.6 looping for FPU :devil: ) @ 10x277 now; GBLA @ 2.67Vdimm.
After I got this one, my wife let me go try the Newegg lotto again to see if I can get another :buddies: :bounces:
More on this one after I have gotten a bit further in the testing/burnin curve.
(Oh spi was easy @ 10x300, but won't do much else, so not good enough for me since I use this for Rosetta )
Speaking of which:
ROSETTA HAS BEEN THE BEST STABILITY TEST/BURNIN TOOL for AMD DC. Go look in the rosetta forum and if you like what you see, XSTM would like to see you. PM any of our admins (see sig) and we can get you set RIGHT UP. :D
Originally Posted by K.I.T.T.
That's the answer to K.I.T.T.? Sorry but I always doubt when the quote is behind :D If yes that means with 180 divider I can use the 10x multi on my 165? :slobber:Quote:
Originally Posted by mad mikee
Nick,Quote:
Thank you very much. Placing an order right this moment.
lop
Hey man, mine's the same way.. I think it will do either 2808 or 2817 with 1.45v but 2850 seemed to need at least 1.55v. I didn't really test over 2800 much though as I'm fine with that..Quote:
BTW no-nick, what method of burning in are you using? Since we have the same stepping I figure I might as well try it
just priming over night .. i have it for 3 days now, and it seams that over night sessions helped him to do same clock with less vcore .. as i said, this is my first chip that with days needs less voltage for same clock .. but dont forget, burning will not help achive higer oc, only less voltage for your max oc ..Quote:
Originally Posted by Repoman
just saw that I already postet this result:rolleyes:
K.I.T.T./ mursaat
Your mem will run @ 9/10th of your CPU HTT (180/200)
Example: If I run 9x300HTT (2700) w/ 180 divider, mem runs @ 270 FSB so 2700/270 = ?:hrhr:
Just try it and see, some CPU's may be picky :shrug:
Oh and if FX-60 = 2.6 Ghz @ stock, what is 2.8Ghz @ stock (DMM measured 1.35) :D (Dual priming for 1.5 hrs so far, large FFTs 10x280 :bounces: )
Originally Posted by mursaat
Got a new one in from Monarch
Get this guys, i ordered this over the weekend... STILL SHIPPING 0550s!!!
http://img.photobucket.com/albums/v7...l/90385491.jpg
Just ordered a proper dual core Opty rig :p:
2 x Opty 265s and an MSI K8N Master 2-FAR.
uwire mod should take it to 1.5vcore and it's got a fair amount of HTT adjustment from the BIOS, so should technically be able to take them to 2.7GHz. I just wonder how the cores differ from the 939 dual core Opties (other than the memory controller).
Anyway, greatly anticipating the bits, should be fun!
Nice One! Did they include the crinkly lizard-skin hand for free? :p:Quote:
Is it the same stepping as this one?
http://www.realsculpt.com/gallery/hand.jpg
Nice! :DQuote:
Now you plug that sucker in and give us some resultos..pronto! :p:
..mine is on it's way (somewhere over the Atlantic by now)...I hope it doesnt get the "coldbug" up there :rolleyes:
Heres my Cabye 0540FPMW.
http://img52.imageshack.us/img52/2457/klock6cp.th.jpg
Nice clock but in wrong thread I'm afraid:p:Quote:
Originally Posted by EboNova
Could you post the link to the wire mod on K8N Master? Thanks.Quote:
Originally Posted by unclean
anyone get 165 0550 vpmw, is it a good ocer?
Definitely mate! I have a bunch of results from my VPMW, here's the threadQuote:
Originally Posted by skycool
http://www.xtremesystems.org/forums/...ad.php?t=90260
Ok, I thought about a x10 multi in the processor :D. And yes, memory dividers appear and dissapear depending of the HTT x multi I set with my 165.Quote:
I get ya buddy, but having BH-5 makes it near impossible. The maximum it'll do is about 263 MHz stable. Still, IMO 2808 MHz is hardly shabby. So you think i should still burn in to lower volts? If so, do i start burn-in at 1.42v, or lower it first, if you get what i mean?Quote:
thanks buddy :)
yah im verry interested in proper burn in techniques, i have a new one coming soon and want it burned in right this time..
Im guessing clock it @ 1.3V as high as she will go
then burn in max stable speeds at 1.3?
I would like to know how u did it..
did you order OEM or Retail?
