Zalman ZM-F2 is okay..i got it in the other rig and it blows like sting but is not so loud..simple, black and effective.:up:
@Brian MP5T & mad_skills: Thanks! will look into it :)
Cleaned up a bit more in my Antec P180-case. :)
http://img181.imageshack.us/img181/9772/mg4718xs1.jpg
Cable management is very easy in that case, plenty of space behind the mobo and nice cutouts for the 24pin and 8pin power, the older p180 was a pain in the ass, but the p182's are alot better
Great cable management Sagart
Taylor, your 'rig' is obviously the best looking one on this forum! ever!
ahhahhahh
Just got these on a few days ago, wonderful gpu coolers (excuse the watercooled cpu)
http://i104.photobucket.com/albums/m...5/IMG_0840.jpg
http://i104.photobucket.com/albums/m...5/IMG_0842.jpg
check my crazy good cable management ;)
http://img264.imageshack.us/img264/9...ycablesqs2.jpg
http://img264.imageshack.us/img264/5983/hardcoreht3.jpg
@pvdonuts SLi looking good with those Zalman's.:up:
just going to install my e8500 that i got back from RMA so thought i'd take a pic first (spec in sig)
5Mpixel - taken with my new Nokia N82 :D
http://img243.imagevenue.com/loc33/t...4_122_33lo.jpg
The Noctua fans look amazing, btw does the hr-03 need that many fans ?
yay 100 pages as soon as i get a camera i will put pics of my pc
@Origin_Unknown, why do you have a fan ziptied to the TRUE? Do the fan clips get in the way? Got enough Noctua fans? :D I should be getting that mobo by the end of this week and i'm hoping i can mount my TRUE like that too. Sure looks like a tight fit. I got an extra 12cm fan sitting here and your pic just gave me an idea on what to use it on. ;)
its got a 120mm and a 80mm - the 120 is over the main body of the heatsink and the 80 is blowing onto the pwn area. When i didnt have a case the pwm's got hot and i've just not bothered taking it off again :rofl:
it's zip tied because the chipset cooler leaves about 2/3mm gap with the true mounted so the clips would have a problem fitting.
the noctua fans are ok, not what i expected but i might get one for the hr-03-plus to make the set complete ;)
oh? whats the idea :D
It took long time to make it looks like this :)
http://img99.imageshack.us/img99/8610/picture018yz7.jpg
Do you guys think that the optional asus fan is a bad idea there ?
my x1900 crossfire: :up:
http://i223.photobucket.com/albums/d...ossfire_01.jpg
Take the blue sticker off the RAM cooler and it will look even better :up:
Please, don't quote images
