on the positive side we now know that one of the caymans is 26 cm long :ROTF:
10.5in sounds about right
Good and acurate reviews aren't made in one day...Quote:
they will send them a bios updated 1-2 days before the release saying : " ok put all your workaround in the trash, here's something new, sorry for have make you loose your time ? ""
And i if would reviewer i wouldn't accept this bad joke.
my english was not maybe good ( im hungry that's maybe why .... freee cookies !!!!) , but i was saying i don't believe to it for this exact reason .....
Peoples really can imagine AMD are sending to reviewer crippled cards and then will send them the real cards ? or the real bios 2 days before the launch ?
edited for the sake: " but all reviewer and tester are not in the same bag "
Fortunately for me, my missus says that the length of it is not important.
All this speculation has been fascinating. I am enjoying reading this thread but to be honest I will not upgrade until a card comes out that is at least a 60%-70% faster than my 5850. (I don't care what colour it is either). I am CPU limited at the moment. I plan to go i5 soon, perhaps my position on this will change then. :shrug:
Update: Hold the presses, it's faster
Big surprise, Fuad admitting he was wrong. Here is the update at the bottom of the article. Wonder who are his "usually well informed sources."
I know most of us new the article was based on fake slide and not on "AMD's own benchmarketing data" as Fuad originally claimed.Quote:
Update:
It appears that our usually well informed source failed us, and forwarded a photoshopped roadmap. So, we plainly got served. We are in the process of gathering more reliable info on Cayman performance and we will write an update as soon as we get something worthwhile. It will clearly end up quite a bit faster and we apologize for the inconvenience.
The good news is, that we no longer have to wait for the article to be proven false or true as SKYMTL suggested.
FUD finally got his asssss kicked! :yepp:
Re-living the R300. ;)
What !!!! is source is just not Nvidia ???? I have miss something,,
Now for be real .........
well after all the bad press he have got, and all the hype around Cayman we have got on forum i will ask me if Nvidia have tell him: " more hype is good, push it a little bit further ! " ..
he he, maybe he was not so wrong after all .... don't expect too high, and you will not be deceipt ..
Not the best idea to leave your name on the card like that from the NDA perspective. :p:
Nope, just did! Can't be just a simple mistake, IMO. But I can not really explain it... Perhaps, NDA related?
Possibly, and, hopefully you're correct.
This is nice, but he may very well be deluded, again.
Yeah, what happened to that? Going through the last batch of rumours, they do not really indicate that it's going be the new R300... Guess we'll see.
He was never deluded, he knew from which slide he calculated the performance. It was the same fake slide somebody posted at some Chinese forum day before. His mistakes:
1 Claiming it was "from trusted sources"
2 Claiming it was "AMD's own benchmarketing data"
3 Problem with his math, calculating from the fake slide that HD 6970 is 20% faster than GTX 480 but at the same time slower than GTX 570
fud,fud,fud,fud.........sounds like a flat tire :p:
http://www.czechcomputer.cz/product....25#description
Yeah, let us know the ROPs, why not the SPs. :(
6950 too.
http://www.czechcomputer.cz/product.jsp?artno=84726
If the 6970 is using 250watts of power (like a certain rumor has suggested), it will spank the 580 no problem.
edit: My 6970 prediction.
You know what I find interesting? Less than 5 days to go and not a single die shot has been found. This must be some kind of record
ts ts ts, its painful to see all the trolls starve to death in this thread as theres not even a chunk of bone of info for them to chew on :D
come to think of it, i did hear 2000sps as the next step after cypress loooooong time ago... (before cypress launched)
but i really hope cayman is more than that, i mean come on, the ipc tweaks wont be massive and 1600 to 2000 is a 25% boost only...
but if the die size numbers are true, then it cant be more than 2000 really... :/
i would have loved to see a 2400sp monster with a 250W+ tdp...
but then again, it probably would have been very expensive and going dualgpu wouldnt really have made sense anymore...
i mean think about it, if your in the same tdp envelope as a dual gpu card almost, then theres not gonna be a big perf boost by going dualgpu, so then you pretty much kill the dualgpu option... since ati continues to rely on dual gpu, that caps their highest single gpu cards to be around 200W, and again more than 2000sps would have meant way low clocks and wouldnt have been much faster than 2000sps...
2000 sps sounds a bout right for 400mm2, thats a 25% boost, then add a 15% ipc boost, which i think is generous, and you got a 40% boost over a 5870, which puts it in 580 territory. might beat it, but not notably...
and after all, justifying a 580 is already hard to do with the lack of nice dx11 games out there...
so a monster cayman wouldnt really have been useful would it?
