ok, thank you for your feedback :up:
Got it up and running finely the Corsair memory 2000MHz anyhow XMP detects it and sets it to the correct specs.
^^1.65 VDimm or 1.65QPI/VTT? What is your QPI set to when you use XMP? I think thats what zsams is referring to.
Thanks for looking out,
qpi 1.25v is it ok or too high?
I forgot to mention this but when I replaced the stock heatsink on the board yesterday I noticed the heatsink totally skips rows of mosfets and the EK block covers them they must not be the important mosfets :p
Am thinking of getting 2 Crucial RealSSD C300 64GB and raiding them in sata3 6.0 is that possible with this board! Or can it only raid in sata 2!
Do you guys know of any settings I need to change (or possibly jumpers) to boot with a PCI video card? I'm setting up for some high PCI-E runs but I can't get it to boot with the 440 FX or whatever the hell it is. The seller confirmed that it worked and it starts, but the board hangs on VGA.
Any suggestions?
running with an old matrox pci vga card my tests right now. there were no special settings required. everything at default boots without any problems.
so yes it should be possible. may be just some sort of incompatibility between the r3e and your card. try another pci vga card ...
Page 100 ! GG
Is it like this: http://www.xtremesystems.org/forums/...es#post4437898
There is picture and explanation. If it's like that, then you are OK. :up:
Hi all, thinking of buying a RE3 when I shortly make the move to socket 1366. If I have EVGA gpu's will there be any performance issues running them on an Asus board? Stupid question I'm sure but I've never really had multiple brands in this area.
No issues, don't worry. :welcome:
:D Yeah, big black ones are chokes and small silver ones are MOSFETS.
Yes! 100 pages! Congratulation to everyone on good advices and experiences shared here! :clap:
:ROTF:Crazy man iam feeding Qpi volt on air 1,63v and pci-e at 113Mhz, Bios 1003 to get this http://valid.canardpc.com/show_oc.php?id=1373064
i have strong cpu and its alive yet :up: Vdimm at 2,5v tested to and not killed mem controller.... :eek:
:D
^to you too donmarkoni
http://hwbot.org/community/submissio...eme_250.34_mhz
You shouldnt need that many volts man, dont kill it! :eek:
:D trying Qpi at 1,72v now :rofl: still live bclk at 247 and then alot of blue screens
No, it's not, check this out: http://www.xtremesystems.org/forums/...postcount=2355
You don't need to kill it, you can always send it to me, and I'll keep it warm and cozy. :D
