OC_NUB can I see your template for 4.5ghz ?
This has worked pretty good for me.
Frequency Control
CPU Clock Ratio ( 21X )
CPU Host Frequency (Mhz) ( 215 )
MCH Strap ( 1333 )
CPU Uncore Frequency (Mhz) (x17)
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 105 )
Memory Feature
Memory Control Setting (Enabled )
Memory Frequency ( 2:8 )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( Auto )
tCL Setting ( 7 )
tRCD Setting ( 7 )
tRP Setting ( 7 )
tRAS Setting ( 20 )
tRFC Setting ( 60 )
Command Rate ( 1T )
Voltage Control
EVGA VDroop Control ( With VDroop )
CPU VCore (1.4375 ht disabled) {1.4625-1.475 ht enabled, cant remember exactly with ht, load vcore is 1.411v)
CPU VTT Voltage (+75)
CPU PLL VCore (1.50)
IOH PLL VCore (1.50)
QPI PLL VCore (1.175)
DIMM Voltage (1.60)
DIMM DQ Vref ( +0 )
IOH VCore (1.175)
IOH/ICH I/O (1.500v)
ICH VCore (1.050)
VTT PWM Frequency ( 250 )
CPU PWM Frequency ( 800 )
CPU impedance - (auto)
QPI signal comp (auto)
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Enabled )
CxE Function ( Disabled )
Execute Disable Bit ( Disabled )
Virtualization Technology ( disabled)
Intel HT Technology ( Enabled )
Active Processor Cores ( All )
QPI Control Settings ( Enabled )
QPI Link Fast Mode ( Enabled )
QPI Frequency Selection ( 4.800 GT/s)
OC_NUB do run this setup 24/7 at 4.6 ? at these volts ?
I run it 215x21/4.5ghz with these settings 24/7. The chip was in my last motherboard running 4.5 for probably 6 months or so.
Same template as above, 230MHz BCLK 3D stable so far (Black Ops for HOOOOOURS! :D).
well i finally got above 217bclk:D
thanks zsamz,mafio,OC nub and kup for all your guy's help :up:
vcore is way high ,needed to rule cpu(vcore)out 100%:D
http://i56.tinypic.com/2ltorbm.jpg
http://i54.tinypic.com/16a74m9.jpg
Nice radaja. :up:
Will you switch back to Giga now or keep testing the E760?
good work radaja :yepp:
thanks,i will test this one for a while and then make a decision.i know i couldnt do 226 bclk stable on the the UD5 but could on my last UD3R,i could boot and run the quick superpi 1m at 230 with the UD5.but it looks like with this E760 230 stable might be possible for sure:D
thanks:D
I didn't read all good job you guys are doing for raising the BCLK-wall. Could somebody give a quieck summery on important adjestments.?
I'm trying to pick some idea to use on SR-2. Diffeent BIOS and chipset may make a big different though, but it's worth to get some ideas and trying.
guys cpu n qpi signal less = usin less volts:D
some boards might be ok for auto:p:
i was gonna post my 231blk x21 template but i need to tweek it
as soon as i get my psu back ....
ti'll then:p:
I think cpu & qpi signal less or auto is different for everyone.
Do you guys know, if a Q3QR runs on a Classified withou a mod?
i finally got 230bclk stable,thanks to zsamz:D
now i just need to up the multi and lower some timings
and i will be in heaven:)
http://i54.tinypic.com/2eyj7ec.jpg
http://i56.tinypic.com/24n2zba.jpg
heres my settings,i now need to tweak some voltages down
but it makes a good starting point for others.
Code:Frequency Control
CPU Clock Ratio ( 15X )
CPU Host Frequency (Mhz) ( 231 )
MCH Strap ( Auto)
CPU Uncore Frequency (Mhz) (3910MHz x17)
PCIE Frequency (Mhz) ( 113 )
Memory Feature
tCL Setting ( 8 )
tRCD Setting ( 8 )
tRP Setting ( 8 )
tRAS Setting ( 24 )
tRFC Setting ( 88 )
Command Rate ( 1T )
Voltage Control
EVGA VDroop Control ( Without VDroop )
CPU VCore (1.32500)
CPU VTT Voltage (+150)
CPU PLL VCore (1.8)
IOH PLL VCore (1.8)
QPI PLL VCore (1.35)
DIMM Voltage (1.63)
DIMM DQ Vref ( +0 )
IOH VCore (1.35)
IOH/ICH I/O (1.65)
ICH VCore (1.12)
CPU impedance - (less)
QPI signal comp (less)
CPU Feature
Turbo Mode Function ( disabled )
Virtualization Technology ( Enabled )
WOW Great job radaja.:up:
Well done dude! :D
EDIT: Was PCIE @ 113 essential for you?
thanks,couldnt have done it with out your help
thanks for your help in understanding the board
well i havent tried lower yet,but now that i have a solid 230
i will test individual voltages and setting to see whats needed
and whats excessive.will post my findings and leave an updated template:D
finally a decent memory score,at least for me:D
still working on lowering stuff(volts)but soon i will have
this MB nailed down and make it do what i want:rofl:
http://i55.tinypic.com/9uvgc1.jpg
