Is the question for me Leeghoofd or someone else? If the question is being asked of me then the answer is that I was trying to get everything I could get out of the system during each test HT enabled or disabled. I can test at the same 4.6GHz clocks (HT on or off) but I can’t get the processor cold enough to test at 4.75GHz with HT on. If you or anyone else would like to see a direct clock for clock HT on/off comparison in Vantage @4.6GHz I can run the other Vantage test with HT disabled with matching GPU clocks?
