Q6600@3600w/1.28v BallistixDDR2@1200Mhz
Originally Posted by
exackery
Hi all I've read this post (and yes its getting long) from start to finish and referenced it a couple of times --> good stuff. Anyway, looking for a 24-7 overclock so I have a Q6600 at 3.6 ghz (using Praz's setup -->thanks btw) and I was wondering about temperatures. I'm using 120 extreme with push/pull 1600 rpm scythe's the northbridge cooler is so close to the 120 I don't use a fan on it. A 60mm blows on the pwm area. Closed case 5 case fans 2 hd 2 optical in a smaller case. Running OCCT 2.0a the system peaks at 68 c on two of the cores the other 2 are consistently 2-3 degrees cooler. cpu temp reads 65 the pwm (system) hits 55c and the northbridge (chipset) hits 45c this is with an ambient temp of about 22c. Idle i'm getting 31 cpu 36 pwm 38 northb. 68 is kinda gettin up there anyone think this is a problem?
I got these temps on my core with this bios config:
Code:
PC Health Status
Adjust CPU Temp: +9
CPU Feature
- Thermal Management Control: Disabled
- PPM(EIST) Mode: Enabled
- Limit CPUID MaxVal: Disabled
- CIE Function: Auto
- Execute Disable Bit: Enabled
- Virtualization Technology: Enabled
- Core Multi-Processing: Enabled
Exist Setup Shutdown: Mode 2
Shutdown after AC Loss: Disabled
CLOCK VC0 divider: AUTO
CPU Clock Ratio Unlock: Enabled
CPU Clock Ratio: 9x
- Target CPU Clock: 3600
CPU Clock: 400
Boot Up Clock: AUTO
DRAM Speed: Auto (2:3 divider)
- Target DRAM Speed: 1201
PCIE Clock: 100mhz
PCIE Slot Config: 1X 1X
CPU Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
Voltage Settings
CPU VID Control: 1.28125v
CPU VID Special Add: AUTO
DRAM Voltage Control: 2.150v
SB Core/CPU PLL Voltage: 1.51
NB Core Voltage: 1.504v
CPU VTT Voltage: 1.255v
Vcore Droop Control: Enabled
Clockgen Voltage Control: 3.45v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: Enable
x CPU GTL1/3 REF Volt: 88
x CPU GTL 0/2 REF Volt: 88
x North Bridge GTL REF Volt: 96
DRAM Timing
- Enhance Data transmitting: FAST
- Enhance Addressing: FAST
- T2 Dispatch: Enabled
Clock Setting Fine Delay
Ch1 Clock Crossing Setting: More Aggressive
- DIMM 1 Clock fine delay: Current
- DIMM 2 Clock fine delay: Curren
- DIMM 1 Control fine delay: Current
- DIMM 2 Control fine delay: Current
- Ch 1 Command fine delay: Current
Ch2 Clock Crossing Setting: More Aggressive
- DIMM 3 Clock fine delay: Current
- DIMM 4 Clock fine delay: Current
- DIMM 3 Control fine delay: Current
- DIMM 4 Control fine delay: Current
- Ch 2 Command fine delay: Current
Ch1Ch2 CommonClock Setting: More Aggressive
Ch1 RDCAS GNT-Chip Delay: Auto
Ch1 WRCAS GNT-Chip Delay: Auto
Ch1 Command to CS Delay: Auto
Ch2 RDCAS GNT-Chip Delay: Auto
Ch2 WRCAS GNT-Chip Delay: Auto
Ch2 Command to CS Delay: Auto
CAS Latency Time (tCL): 5
RAS# to CAS# Delay (tRCD): 5
RAS# Precharge (tRP): 5
Precharge Delay (tRAS): 15
All Precharge to Act: AUTO
REF to ACT Delay (tRFC): 30
Performance LVL (Read Delay) (tRD): AUTO
Read delay phase adjust: Enter
Ch1 Read delay phase (4~0)
- Channel 1 Phase 0 Pull-In: AUTO
- Channel 1 Phase 1 Pull-In: AUTO
- Channel 1 Phase 2 Pull-In: AUTO
- Channel 1 Phase 3 Pull-In: AUTO
- Channel 1 Phase 4 Pull-In: AUTO
Ch2 Read delay phase (4~0)
- Channel 2 Phase 0 Pull-In: Auto
- Channel 2 Phase 1 Pull-In: Auto
- Channel 2 Phase 2 Pull-In: Auto
- Channel 2 Phase 3 Pull-In: Auto
- Channel 2 Phase 4 Pull-In: Auto
MCH ODT Latency: AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Read to Write Delay (tRDWR): AUTO
Ranks Write to Write (tWRWR): AUTO
Ranks Read to Read (tRDRD): AUTO
Ranks Write to Read (tWRRD): AUTO
Read CAS# Precharge (tRTP): AUTO
ALL PRE to Refresh: AUTO
http://i31.tinypic.com/s1p2fd.png
I use 2 CoolJag Everflow 40x20mm (18CFM) with a Zalman Fan Mate 2 to cool PWM, with that setup there is no need to use water on PWM.
One fan is placed on top of the PWM blowing air to it and the other one is installed outside the case attached in the backplate drawing air from the PWM area. I will post pictures If someone ask.
