Originally Posted by
rge
@cincyrob,
So for accurate LOAD core temps (assuming your load temp is in accurate range of 60-65C+), use tjmax of 95, which you can use realtemp, or set another program to tjmax 95. You can then either ignore your idle temps, knowing they are not calibrated, or calibrate idle temps using realtemp (will not affect accurate range of temps 65C+) so that at idle, at low vcore like you have, they are displaying 3-5C above ambient, assuming like your cpu temp shows.
btw...my 6 in 1 cardreader with internal USB connection occasionally disappears on hard reboots, and I have to manually unplug and then replug back in.
