okay, gl :)Quote:
Originally Posted by alexio
hm I dont have long time ago the dothan rig, can you tell me about pat? how can I test this on 915 chipset?
okay, gl :)Quote:
@alexio
here it is..
Hi!
I have four sticks, two are mushkin blue (is bh-utt) and the others Gskill gh (bh-utt too), my problem is that i'd like to use the best module of each set, i mean, my best mushkin module and my best Gskill at the same time (like dual channel, since in reality are the "same" chip) but the problem is the spd because are diferent, mushkin is 2-3-3 and Gskill is 2-2-2 and if i put the sticks together i only get beeps from my motherboard, with this method can i flash one of them, for example mushkin with gksill gh spd?
Yeah you can do it, but AFAIK Mushkin Blue is CH-UTT ;).
resurect your ram? that is truly amazing, thanks for the tip! :D
Hi i have a pair of mushkin black level II pc3500 bh-5, and one of the sticks shows nothing at all when they are in dim slots no mather wich, one shows good and runs good at 278mhz on 3,7v, i can have both sticks in dimslots and all boots fine but when i check cpuz only one stick are there.
question is the one that there no showing compleatley dead or is there any way to bring it back to life again ????
Try if taiphoon detects it.Quote:
Originally Posted by chefnr1
actually what does you all mean by "dead" sticks?
no, taiphoon and cpuz dont detect at all, must mean it´s totally dead or am i wrong???
If neither cpuz/or thaipoon cant find the mem/spd there is something wrong.. Try other motherboards hopefully they will work!
ok will test that on my second rigg nf7-S ver 2.0 it.s my only that can take ddr sticks, i've just sold my rdx200 board, i'll report how's it goes..
nothing happens att all just beeping when the bad stick is in slot, i tested all slots, as i did on my ultra-d i think it's compleatley dead:(
we got the same problem today.
BUT WE GOT THE MEM BACK UP AND RUNNINGGGGG:toast: :toast: :toast: :toast: :toast: :toast:
TNX wouter:clap: :clap: :clap: :clap:
btw 3.8 allready 1M pistable with 780 and ln²:D
I have 2x512mb OCZ EL Platinum Rev. 2 (TCCD) and I've been seeing performance degradation for no apparent reason for the last 6 months. It's to the point where I can't boot into windows with a CL of 2.5 or 3 anymore; it'll only accept 2. I tried to rewrite the dump with the dump posted here but there's no improvements. Anyone have any ideas as to what I can do to get it to work?
Hi Guys,
Anyone have the dump file for Geil One ES and Geil One S ???
Thanks :worship: :worship: :worship:
i had to get my old AMD rig out with an abit AT7, because my sticks wouldnt show. when i used it in my p4c800 it wouldnt post and in my intel shuttle it gave memory beeps.Quote:
the one that i suspect is dead dont show on dfi ultra-d,rdx200, beeping on nf7-s v2,0 so i give up this chip:(Quote:
Originally Posted by Stigggeh
Strange...
My Muskin Redlines PC4000 can´t boot at 6 different Boards (3 x NF4, 2 x i875, 1 x i855) after a CmosClear. They started only from my DFI with 3 V, even I dumped them with the file from the first side.
I don´t know, what happend to them, I bought them used (but dead, what I realized to late).
And now, nothing more to loose I used the file from my OCZ Gold VX PC3200.
Result: they boot after a CmosClear with 2,6 V - now Prime running and testing :banana:
Funny: they are still programmed with 2.0-3-2-6 and shown as Mushkins :confused:
Enclosed the dumpfile from my OCZ VX...;)
i got my OCZ 2x512mb EL Platinum REv.2 @ 3.1Voltage and its not overclockig anymore beyond 220Fsb and i cant run CL-2.5 or 3 because i overvoltage it..
so does that program will fix my problem?? will the OCZ REV.2 will be able to overclock agian @ 300FSB??
if so.....then its miracle
Strange, did it again and now my Mushkins are OCZ, and also the SPD-timings were rewrite...:rolleyes:
From originally 2.0-3-2-6 now to 3.0-3-3-8 and the DFI ist booting with 2,6 V. At the first trial it worked, but after removing and put it in again into the slots the RAM didn´t start.
It still didn´t start from my DFI 855GME...:(
I think, the RAM has a hardware damage from to much voltage...:(
Could somebody recommend a dump-file for a CH-5-Kit with CL 2.5?
stummer... as said in the startpost.. please watch out with placing other spd's in youre mem then the original!
good job
Would anybody upload a SPD Dump from a Twinmos Pc3200 256Mb ?
It's a stick with Powerchips ( AADT )
@Waus: I got you...;)
But they are damaged anyhow, so I don´t care about them.
I dumped the OCZ on the Mushkins, but didn´t work either. So I dumped back with the file in Post #1.
But they still run only with 3 V, doesn´t matter which timings @ 200 MHz.
I have a Twinmos Speed Premium BH-5 with a Mushkin LVL2 dump... Works nice... Had to do it otherwise they wouldn't work together in my DFI Ultra-D...
