They would be gray if the address wasn't correct. Yellow is fine in Fahmon, it is yellow half the time for me (not sure why). In Fahmon go to Monitoring > show/hide FAH log so you can see what is going on with the clients. If your CPU is at 90% (I'm guessing in the setup you didn't set it to 100% CPU usage) and the cores are runnng then that sounds like it is running properly :)
:welcome: to the team :toast:
