Msi k8n neo2 plat
2x512mb OCZ VX
booster
3,2:
240mhz
memtest stable.
3,5v:
http://img135.exs.cx/img135/5972/273sandra1fp.jpg
:banana: :banana: :banana:
Thats not memtest stable though
Msi k8n neo2 plat
2x512mb OCZ VX
booster
3,2:
240mhz
memtest stable.
3,5v:
How high can you go memtest stable?
Dont know yet, but i'm running 230mhz 2-2-2-5@ 3,2 24/7Quote:
Originally Posted by Garrett
i got one stick that can do 270 @ 3.5v and one that could do 255 and now it does not like voltages above 3.3v or i get errors .
I will contribute to this thread soon as my DFI is modded.
Seems me and Tedy have the same sticks...Hopefully I can get 260 :toast:
Great job everyone..Begining to love this forum..Team work
Esdee..Good luck..shoot for 270 :toast:
ok good news
my MSI is crap!
my twinmos (the ones i had since the beginning - not speed premioums)
did 240 at 3.2V (Vio modded the MSI)
i you can recall 240 was my limit with 3.55 too!
odd wall. Monday ill have the DFI ultra, so we will have some 260+ action!
forgot to mention
MSI Neo2 1.3b6 BIOS Vio modded
Winchester 3500+
Twinmos UTT (not speed premioums) 04514 AA4T ending P/N
240@2-2-2-5@3.2V full load,3.3V idle
El Snorro,
could you test your modules to find their max MEMTEST STABLE point for voltages 3.1v,3.2v,3.3v,3.4v,3.5v,3.6v please?
for more info bout MemTest/timings requirements check out first post in this thread.
Wingz, you too please :)
godsa, thanks dude... look forward to your results.
esdee, once you get the DFI would you mind posting results too please?
cheers all :toast:
Hello
Sorry I dont have any contributions, but I have a question
My prime95 keeps giving me calculation errors? Even at pc3200 speeds with the correct timings
Sometimes it will work, and sometimes not
But I've been able to do 2-2-2-4 at 220 with 3.35 volts so far
mobo wont boot above 220 :(
ordered a dfi ultra-d so it should be here wednesday then the fun begins ;P
Hopefully theres nothing wrong with the ram and its just my mobo acting funny
Holy sheeeeeet!
Wingz, what are your complete specs dude?
Timings, Components, Cooling...
That is amazing!
Originally Posted by Wingz
amazing bro holy sheeeeet indeed :toast: :banana4:
maybe it is because you have version 1.0?
argg rabbi your the 5th person to ask me that question and the specs are in my sig.Quote:
Originally Posted by Rabbi_NZ
i have a 92mm fan attached to the zalman bracket cooling the ram.
Could you give complete timings please?Quote:
Also, how good is your other stick?
Ay guys..im trying to test out those TMII400 sticks I have and need some assistance on my timings as well
Tras 6
Trcd(read)3
trcd(write)2
trp2
cas latency 2
trc 12
trfc 14
all the rest are on auto
Scratch the 250 i just finished 255 for 15 passes..looks ok so far..260 did give errors tho
I did 250 with no errors..but I am clueless if these timing are correct or not..
3.3 v
for some reason the other stick now does 260 but still does not like voltages 3.4v or above so i am now able to run both sticks @ 260 - 2-2-2-10 with 3.3v on the booster (multimeter shows 3.35v)Quote:
http://www.hvweb.co.uk/wingz/260%2Ejpg
Would you mind testing them from 3.1v-3.6v as described in first post please? :)
erm... :confused:Quote:
beer distracted meQuote:
Originally Posted by pik-ard v1.1
lol, you've gotta catch one of those "sober" moments while you've got the chance. ;)
Remenber this stuff was http://www.newegg.com/app/viewProduc...218-062&depa=0
Pics of the memory and stuff all the identifying marks
http://www.xtremesystems.org/forums/...753#post696753
Ok Im done with my contribution..here ya go..and guys thanks everyone here is awesome.
All this was memtest stable for 25 passes
Tras 10
Trcd(read)2
trcd(write)2
trp2
cas latency 2
trc 10
trfc 15
I did manage to go further with the trfc 15
3.1v 254
3.2v 257
3.3v 261
Enjoy when i get the other sticks of Speed I will post as well
Specs let me c...
92mm Tornado on the chips...
DFI "LANPARTY NFII ULTRA B" stock bios..no mods
2600 Mobile (Stock Cooling)
The Memory chip numbers..
TWINMOS
512mb chips
05034
TMD7608F8Ε50D
Pic of them...
http://www.xtremesystems.org/forums/...chmentid=23897
TwinMOS Dual Channel Kit 184-Pin 1GB(512MB x 2) DDR PC-3200, Model TMII400/1GB - OEM
Want to add..one stick absolutely sucked...only did like 240 and thats just horrible...
does lower cpu multi really help in memtest?
godsa,
Could you list your specs please...:
Brand & Amount of memory
Motherboard/chipset
Not for meQuote:
Originally Posted by MarilynMX
MarilynMX - I just noticed that you're running at 3.9VDIMM. That is beyond wicked, man. :slobber: Did you measure that voltage on a multimeter to confirm it?
Upgraded averages on first page... they will not be accurate for all platforms due to the fact they include all dimm sizes, chipsets, brands, cooling, etc... but some will find it useful :)
conrad, il pm soon as i get some food in my belly! good to see you round again bro.
Conrad: I dont have multimeter so I cannot find out if the volt shown on booster is accurate. My ram refuse to work at 266MHz w/ VDIMM less than 3.9V(4V idle). I know it's more than weird since I'm the only one with such experience. Another thing is booster is not affected by tunning in-BIOS VDIMM(which is totally different from my previous RMA'd booster).
PS I noticed FSB(HTT) range ocassionally varies in Corecenter. For example, I set 240x11 1:1, FSB range varies from 23xMHz to 25xMHz sometimes, that was abit freaky but same thing doesnt happen on cpu-z.
My computer reboots ocassionally without bluescreen or any other warnings. vcore 1.50~1.54, 3.3/5/12 = 3.34/5.08/12.56~12.74, VDIMM idle up to 4V depending on FSB. anyone can help me figure out the probable reason?
