maybe with winter coming to OZ can get ambient room temps under 26C lol but card sighQuote:
So 450/1200 @ 25°c is faster than 450/1200 @ 50°c?
I'll just get some icecubes to cool the rad ;)
http://service.futuremark.com/compare?3dm05=678845
i think this is a nice score for a rookie
Actually, at 42C load, my cards clock at around 470/1260. Then, with load at 25C, I can hit around 500/1280 or so. The ambient temp of the chilled water is about 12C.Quote:
Originally Posted by Arnar
Arnar,
GREAT scores....
You smoked me in '03... that 500mHz CPU lead over me and that GT1 just kills my 24.1k......
I've still got you in '05, probably from WinXP/Rivatuner tweaks....
I dont have any tweaks, just overclock core and mem with Rivatuner
Maybe you could teach me some? ;)
Thanks for the compliment, coming from you.. its great ;)
Arnar,
Well... just a few of the obvious ones...set bench to "realtime" and set LOD BIAS to "3". That alone will let you take out my '05 score :D
And polish up your XP a bit... set theme to "classic" and "best performance", remove wallpaper and set to 16b color....
C
charlie, the SLI link for 05 in your sig needs 1 less set of "http://".
Nice scores!Quote:
http://service.futuremark.com/compare?3dm05=680204
3d mark 2005: 10786
so, i'm at my max here, everything on air no volt mods etc...
and my cpu wont go any farther.
thanks torin... fixed.Quote:
Originally Posted by Torin
interesting 3d2k3 your card clocks and cpu are about the same 23,921 http://service.futuremark.com/compare?2k3=3716887Quote:
Originally Posted by charlie
i don't use LOD tweaks so is that the difference right there ?
yeah, probably. I used LOD3 and something else in Rivatuner, just can't remember what... I'm not much into Nvidia drivers and tweaks...Quote:
Originally Posted by eva2000
C
EVA2000,
THat's weird... you KILL my GT1... hmmm maybe the tight timings???
Strange.... I need to try some UTT!
Nice scores!Quote:
Results posted.
Arnar, you destroy my GT1 results. I wish I had an FX, right now. FX does a better job on the first test than the plain A64 (CPU intensive test). But, on latter tests, higher video clocks make up a bit of ground, since they are more video intensive. I think the higher clock and bigger cache of the FX definitely helps the first test.
EVA2000, what was your FSB on 03? I could look at the result, but the FSB on that is usually inaccurate. I ran most of mine around 302-305 FSB with 2.5-3-4-9 timings. I wonder if tighter timings are better than higher bandwidth on some tests. Your GT1 is better than mine. I guess it could also be that I push my cards a little past prime, since the other three tests more than make up for the loss on the first test.
Great score. Anything approaching 11K is a very respectable score. And, that's with GT's and your CPU at 2.4 GHz. Not bad at all!Quote:
Originally Posted by C_X
yeah probably ram timingsQuote:
all my settings/fsb are in compare url descriptions ;) you folks should do the same just save base description in txt file and copy and past after submission :DQuote:
23,921
3200+ 90nm @9x300 = 2701mhz - 2x eVGA 6800U stock @454/1215 - 2x256MB Kingston KHX3200K2/512 BH-5@270mhz 2-2-2-6 8-14-2212 1T - DFI NF4 SLI-D 217 bios - 580W Topower 686P6 35A/12V (eva2000)
Thank u, but i orderd a fx55 and i hope i finaly can get to the 11K
http://service.futuremark.com/compare?3dm05=687427
finaly i have the 11K and i am finaly at the top 10 here, what an honor :D
Nice work!
And, with that score, we now officially have 11K as the entry point to the top 10 list.
don't forget your XtremeSystems.Org 3Dteam TAG!!!!!Quote:
C
tag added
is it good like that?
Looks beautiful... nice big score, too.Quote:
C
