Port 80 is network talk for the port that all html communications take place... it's the port you hit the internet through when you are browsing the internet or downloading a file... or uploading weather stats.Quote:
Roger that.. It sounded fimiliar.. Well I have the weather station running and cleaned up all un-needed Win garb is gone.Its not much A64 3000, 1g 3200Xl mem, 40g hdd but it has a fast network hookup... So off we go to download and get crackin.. I have installed the AMD Dual Op board may have it up and running this weekend.....Thanks for the help...Quote:
Originally Posted by Rodzilla
Good to have u on the team. This is a general question, but on his dual opteron setup, would he put 2 installs on there, right. I'm pretty sure u would load it twice. Wait for a more certain answer before u do it.
Well my Weatherstation computer is up and running XS_D2ol1 and the daddy program I believe.. Not sure on how to monitor it or if my user name is associated with it or not. So any help would be appreciated.. Man hope this little system can take it.. My CPU usage is at 100% during idle...PF Usage is 232M..I might have to open the case cover and turn an extra fan on...
I've got a newbie question: Why just set it to download 200 tasks at a time? Why not 2000 (max) or somewhere in between? I myself am sitting on a 10/10 connection and hd space isn't a problem either. How many tasks do you suggest I enter?
:toast:
As many as you can 2000! :up:
The more the better, because although they dont happen alot, sometimes the task servers go down, and we can be stuck with only the cands that we downloaded.Quote:
Originally Posted by krille
OK, I run this at night after I go to bed but mommy usualy turns it off before the next update. ANyway to change the update interval or is there some way I can have it save the work i did, because I think I lost a lot on Cands last night before it got updated...
it saves the work you've done. If you exit out of the program and reenter, all the cans you had done are still there. You can run a maual update so it uploads what you have done tho.
jjcom
Ok, thanks all! Gonna change it to 2000 then. :thumbsup:
Thanks to moddolicous and jjcom for helping out! :up: That's what makes this team so great!
back up after reinstall. .prp backup went smooth thanks to very good guide & very helpful members. I had a bad feeling while down, kinda like sports when you let your team down.Hopefully get back to my 100+ soon.Would like to increase that. When i get this rig under water i will be able to put 2.4c@3.1 up on line.
No need to ever feel bad about your output! :up: As long as you do what you can... and for as long as you can... we are greatfull! :up:Quote:
Originally Posted by heater918
I've lost my new install, everything was fine no issues & no oc. I was on XS looking for the eggs when screen flickered & than a reboot, BIOS screen came up & showed damaged raid array. I have used western digital's diag.tool and i checked it again shows no problem with raptors. This started in Nov. after a power outage i have had problems since. Started with hang on welcome screen than it would go to black no BSOD,after trying different things i was unplugging periferals & when i unpluged printer it booted fine so i thought i had a driver issue removed driver & reinstalled new driver seemed to work fine, than for no reason keyboard quit,it started working after reboot.
This leads up to the last install when i used ghost9 to image clean install with only basic drivers etc. So when it crashed surfing web i ghosted copy with no problems worked 1 day & did the same exact thing flickered & rebooted to damaged raid array. I,m on my 2nd. ghost reinstall for 3 day's now working normal? The only error message has to do with pnp windows drivers that are loaded with XP is it possible that my XP disk is some how flawed or damaged?
Sorry if this makes no sense & is long but this is just driveing me crazy not to mention my production has gone to sh##. :brick:
Are the drives still under warranty? Perhaps it is best bet to RMA. After what you've done with the fresh install and all, and then you're having the same problems with it? Sounds like hardware to me.
How does a substitute hdd work? Do you have one That way you can isolate it to the HDDs.
ter to replace them.Quote:
Drives are warranted for 3 more yrs. The way i understand there diag. program it checks for problems than makes report if there are any issues involving drives the report is allready in there data base ser.# etc. it comes out clean. Not 100% sure but according to W.D. there is no rma issue.
I'm leaning towards this PNP plugnplay issue because of the USB printer & keyboard problem, that also includes drives right?
These drives are 36g. Raptors in raid 0 with 110g.seagate for backup.I have had them in raid0 & run seperatly in past with no problems.
I use same raid driver in F6.
It seems to work now for 3 days on this ghost image(same image that crashed after 1 day). I have a 10g. partition on backup that i could install OS on & double chek drives i just thought with testing i had eliminated drives.
Yeah, I understand how they want you to run their diag. apps. But still, even if there is no problem ( according to their app ) reported, BUT the problem remains, then I'd insist on an RMA.
That is [i]if[/i/ you can isolate the drives as causing the problem. If you can do that, and eliminate the PNP driver thing as being the thing,then I don't see how they can refuse you.
Thanks Serly i appreciate your input. I agree it sounds like a drive problem. That windows error p.n.p. thing could have been caused by ghosting, the fix was slipstreaming drivers in. That error has not happened again. I will try a 30 day install on my backup & if ok will do as you suggest.
Edit The problem that Boshi caused with browser, I.E. crashing etc. Would that maybe have caused my latest problem as i was looking at old post both times. Just a shot in the dark as i assume that was cleared up and i've been fully updayed all along. :confused:
Quick question... What is buffering.and how do you set it up. Does it do anything worthwhile?
Its so you can have a backup of cans ready to go incase someone over takes you. Like you could set one rig to run offline and it would just start storing up completed cans. Then when the time is ready you dump. Nice surprise, esp. if its 2000cans :D
jjcom
thanks jj, wasn't sure kinda thought it was that. So my new op systems would be a good one for the shadows? And is there a limit of cans??Quote:
Originally Posted by jjcom
Depends on the kind of buffering you want to do. If you just want to do it on the computer itself, then 2000 is the limit. (The max amount the D2OL program allows) unless the computer can two threads or more. Than its 2000 times the number of instances of D2OL.
The safer way, is to have the computer crunch and upload, but not add the node to your account. Then when you want a boost, just add the node and all of a sudden cans show up :D
jjcom
Niiiiiiiiiiiice!!!! Thanks.. Ohboy this will be fun...Thanks jjQuote:
i have problem
i install the 2X XS_D2OL
i saw the process running in task manager, but i cant find it in my system tray
what's wrong?
If u installed the personal one that rod made, it doesnt run in your try, it runs as a service.
