mmmmm wonder how it works in NF2 ?
Ok.. Ran some Benchies at 265x10... same as before But I used 3.6V.. This seems to be the sweet spot for my system (Until I get my Phase change fixed)..
Note: 3Dmark01 was run with a stock Ati saphire X800 pro (no overclocking)..
wow, very impressive. 28k. I can't get a single bit over 23k with my setup. I cant wait to get a 939 setup with this ram. If I could clear 30k with my X800XT I would be exstatic.
is this ram going to be released in 2x256 variety as well?
Originally Posted by hag6br
265*10 1T ?
when will they be in germany? cant find them anywhere
Yep...Quote:
Originally Posted by TEDY
Been Playing and the best I can get is 280x9 @ 2.5-3-3-7 1T..
NO WAY ?!!!!!!!!!!!
280 real MHz ?
yep.. running Memtest right now..Quote:
alternate.de has them for special order if you guys need them in EU
Pretty decent price for EU standards
http://www3.alternate.de/html/shop/p...?artno=IAIDN9&
Hi
Has anyone found somewhere here in England that's going to stock them?
I might have missed this somewhere in the thread, and appologies if I have, but what do these act like at lower voltages, say 2.9v ?
Cheers
Oli
Think Winbond BH memory...it doesn't do much at low volts...Quote:
Originally Posted by Ol!ver
Cheers for the reply, and from a fellow Englishman :DQuote:
Originally Posted by Soulburner
Anyways, I know BH doesnt kick in till you get high volts, but it aint bad at low. I'm running bh6 now, 225mhz, 2-3-2-11 at 2.9v, wondered what the state of play is with this VX.
Cheers again
Oli
my bh6 does 235-240 on 2.9vQuote:
What' so special about 2,5-3-3-7 1T @ 280 ? TCCD can do that at 2,7V.. :rolleyes:
Originally Posted by blinky
Website only shows 512mb sticks or 2x512mb kits.
???Quote:
Originally Posted by reject
how hot do these modules run at 3.3v - 3.5v
on my 2.8C/P4C800-E rev2.0 with 1019.04 bios
Cooling
- 2x 60x25mm memory module length wise diagonally placed on top of memory modules
- 1X 80x25mm sunon 39cfm fan placed over front side of OCZ DDR Booster unit
I attached 2 thermal probes to side of the modules' heat spreaders (middle of heat spreader) and
@ 3.3v vdimm
dimm 1 module looping test #5 = 28C
dimm 3 module looping test #5 = 30C (dimm3 has always run hotter for my P4C800-E boards)
@ 3.4v vdimm - @220mhz 2-2-2-6
dimm 1 module looping test #5 = 29.9C
dimm 3 module looping test #5 = 32.9C
@ 3.5v vdimm @ 228mhz 2-2-2-6 - test #5 looped for 2hrs 10+ mins for 154 passes error free
dimm 1 module looping test #5 = 30.4C
dimm 3 module looping test #5 = 34.9C
Highest temp i've seen is 34.9C and that was on dimm 3 slot which is always hotter than any other dimm slot on my P4C800-E
Without cooling, easily see 38-44C at 3.3v
sorry ocz i was going to wait but mushkin re-released their BH-5 lvII memory so i got some of that, impulse took control of me :(
OCZ should make a cooling device to go over modules like the one Abit made for that dumb Fat1lity board
this thread moves fast :D
Got a hdd, will hopefully have time to set it up tomarrow and complete the benches I started yesterday :D
thank you ;)Quote:
Originally Posted by SteveOCZ
Well I'll be selling my OCZ 4200-EL Platinum (I just got) for some of these babies!... : )
cinders gimme :>
