The Standard PC /ACPI thing?
I know their is a point gain when you change to uniprocessor PC
Can some of you 3dm gurus help me with this problem? http://xtremesystems.org/forums/showthread.php?t=44754
Originally Posted by µnrealneo²
We do not talk about XP. It's W2K.
It has! But maybe with a different effect on 3DMark performance?Quote:
well if this tweak becomes public, me and everyone will use that. In my case ill get like 200 marks boost :) others will gain 300 or 400
ExactlyQuote:
Originally Posted by SKATAN
yah when he said device manager i knew theres really only one thing there that could have a big effect on performance ;)
I think I know too, gonna try and see. If no go, itll be public knowlege soon
I hope those who know what it is that's being done keep there mouth shut.Quote:
Originally Posted by P4rthen0n
the question is, are o/s tweaks fair game? Obvious answer is YES. But WHAT about a custom designed o/s? What if a MS engineer made a skeleton win o/s program just for 3D benching full of optimizations? What if it gave an extra 1000 points? Would it be fair? Where's the line? How 'bout wireframe 3D mods? Naughty, right?
What's the RULE for "acceptability"?
Software and Hardware available to the public?
Tweaks and Massaging no limit?
Hmmmmmm...
Seems to me that the old "set priority to real time" is acceptable and is known to everyone. Obviously the |RICKY| mod is OK, too.
While the ricky mod is a bit more in-depth there are definately limits.. otherwise we would all be running super_pi on *nix with WINE maybe? :D
Nice find btw ricky ;)
From the view of being nr.1 I truly understand Mr.Rocha, Ricky and Macci :toast:
Just thought Xtremesystems was all about sharing info and helping each other getting better :)
Still at 230x10 but faster card (X800XT PE):Quote:
winchester@2300MHz, 230x10, x800pro:
WinXP SP2 => 25248
Win2k SP4 => 25823
Win2k SP4 w/ a64 tweaks => 25918
Win2k SP4 + "ricky special" + A64tweaker => 26388
Win2k SP4, all-out tweaks, stock X800XT PE => 28611
Win2k SP4, tweaks, X800XT @ 669/630 => 29603
I'm fairly sure that a 512k cache CPU at 2300MHz w/ 230MHz ramspeed cant score much higher than that :D
One thing is funny thou: I'm getting silly low Drago low score?? is that cos of 512k cache?
comparison w/ my 1MB Clawhammer:
http://www.akiba-pc.com/939/claw_vs_winchester.PNG
512k is at 2300MHz (230x10), 1024k is at 2394 (266x9)
660/630 vs. 567/612
Same thing happened to me :confused:Quote:
Originally Posted by macci
Havent worked out what kills drago low yet, maybe it was something wrong I did during the win2k install. At same GPU clocks my 3GHz S754 is beating my 3.1GHz FX53 ... weird.
** sigh ** another problem to work out.
Hmm ok so its not a cache problem then? how much difference did you see between s754 and your fx?
tried WinXP too and it was even slower :D
I cant find an exact example in my notes but this is the best example of the drop:
3400+ @ 2970 (11x270), GPU 610/610 -> DL 674.3 FPS
FX53 @ 3127 (12x260), GPU 651/642 -> DL 674.2 FPS :(
same OS tweaks, same AGP settings, same mem timings (full A64 tweaks), same test order, and both CAT4.9.
The FX53 should flog the S754 score :confused:
Only OS difference I can find is that I used 3.13 NVidia drivers on the S754 and 5.11 + M$ IDE driver on the FX53. Also used LDT2.5x on the S754/shuttle and LDT4x on the FX53/giga.
I was thinking that it could be an AGP latency problem or a chipset driver issue, gotta test more to find out.
Drago Low is a VERY "Memory depenting" bench.........Try to run it with HIGHER Ram frequency and you'll "find" your frames/sec...... ;)Quote:
EDIT1 : EVEN 1 or 2 MHz more on Ram frequency makes difference.......
EDIT2 : I also found out that running the VGA at it's "edge" frequency for the DL , makes things worse.......Better lower a "bit" the VGA's frequency when running the DL + More rig's Ram frequency..... ;)
I think macci knows ;)
Gomer - it is, but you cant reveal everything! That'd take the fun and adventure out of learning all this crap ;)
Its 10000x more rewarding to figure out the trick than having it told to you.
If you know it, cool, keep it. If everyone shared all the damn time, wed all have the same scores. How much fun would that be? :stick:
Yes macci might know but there might be some others out there who don't........So I don't think it's wrong to share our experiences!......Is it?...Quote:
Originally Posted by STEvil
So you will share the spec's/design for the Maximizer?;)
In my opinion (ok its worth nothing :stick: )
All us small fish need a helping hand from the big fish :D
Give us half the tweak lol its a start :D i just killed win2k 3 times in a row lol not good :stick:
Spec's are shared and they should be.....BUT the design cirquit it's NOT a tweak or a mod or something like that....so it just can't be shared.......I've shared a LOT of other things though...... ;)Quote:
Originally Posted by G H Z
I dont think its necessary for anyone to divulge the tweak unless they want too. The pressure we are putting on ricky/pedro etc etc is just not fair. They worked it out the hard way, and not by having someone tell them how to do it.
Anyway, macci hinted enough for us to work it out.
I was curious about this, but I only have WinXP. I did do one little device change, the one I thought was obvious, and I don't know if this is it. I got ~23.9k after device change and ~23.5 before. Changed back and still get ~23.5k. Some scores was raised, while some was exactly the same +/- 0.? ...
I doubt this is it, as I have WinXP Home and not W2k. I'll share what I did, if anyone wants it, but this it probably not it.
