my backup rig. loudest part of it is the hdd:
Nothing special, I just upgraded to a Gigabyte 3d Aurora. I still have a few wires to tie down/hide. Nice roomy case, good air flow and QUIET!
http://s88500732.onlinehome.us/case1.jpg
To lazy to buy a case, so it sits in a corner under... a makeshift desk. Just moved so.. no cash to buy good stuff... all.. dry...
Oh, and that 6800 there will have a nv5 on it eventually. I just have to repair the fan leads. Last card wouldnt give it up.
About to switch to watercooling, but the zalmans have served me well :toast:
http://www.xtremesystems.org/forums/...1&d=1137399690
Here are a few photos of my rigs cooling. Not only do i have two 80mm front intakes, but two 80mm side intakes, an 80mm rear exhaust, and another 80mm top blowhole. ALL are panaflo H1A fans. The CPU is cooled by a 92mm Panaflu U1A fan and stuck to that is a Delta 70mm fan blowing cold air directly over my memory.
http://www.kalionzes.com/computers/FullSetup.jpg
Closeup of the ram cooler. At 2.9v they are ice cold. Before the mod they got pretty damned warm.
http://www.kalionzes.com/computers/RamCooler.jpg
My modified Vantec Iceberq GPU cooler. After a little time with the dremel grinding out sections so they wouldn't touch various motherboard components, it dropped my chipset temp around 8'c under full load. Now it hovers around 27'c under full load.
http://www.kalionzes.com/computers/Iceberq4chipset2.jpg
I also have an Arcic silencer on 7800gt video card and will soon be volt modding it with some 5k and 10k variable resistors i picked up today at frys.
what's about this? dual 60mm ram cooler
http://img17.imageshack.us/img17/137...00154so.th.jpg
I dont believe I have posted my Pentium D rig quite yet. Anyways here it is:
http://img.photobucket.com/albums/v1...al/cropped.jpg
added a little more air...
http://www.xtremesystems.org/forums/...1&d=1137574784
Still runs very quiet... the Tornado gets cranked up with the fan controller for benching...
I let the picture speak for it self :toast: Quiet as fu*k and still overclocks hard
http://www.diskusjon.no/index.php?ac...=post&id=53170
Is that a Tt heatsink attached to your NB? :stick: :banana:
And what are the three sinks next to the (I think) floppy connector for? They seem to float above some other sinks...? And I can't imagine what chips would be there.
The chipsetcooler is a modded arcticfreezer.Quote:
Originally Posted by ZMarre
the other sinks is for aditional MB cooling
http://www.diskusjon.no/index.php?ac...=post&id=53168
Details from the mainboard cooling, also had to make a special tool for the job!
http://www.diskusjon.no/index.php?ac...=post&id=53977
very nice passive 'sinking ArcticOC
http://i20.photobucket.com/albums/b242/flytek/case.jpg
i got a 3700+ here just begging for 3ghz on air.
so i should get the TT-BT then?
if the fan is too noisy i can just change it.
the TT-BT is a great choice, VERY quiet fan
heres my rig, just re-wired :D
http://i12.photobucket.com/albums/a2...7/DSCN1703.jpg
http://i12.photobucket.com/albums/a2...7/DSCN1700.jpg
http://i12.photobucket.com/albums/a2...7/DSCN1706.jpg
(used electrical tape instead of heatshrink, but it doesnt work at all :D)
Zalman all around..
http://dubs.unixprohost.com/albums/B3st16v/DSC00933.jpg
http://dubs.unixprohost.com/albums/B3st16v/DSC00926.jpg
FanMate controling the speed of the 100CFM exhaust fan
http://dubs.unixprohost.com/albums/B3st16v/DSC00931.jpg
FanMate controling the speed of CPU fan
http://dubs.unixprohost.com/albums/B3st16v/DSC00935.jpg
The 9500 and VF700 are incredible. I picked up automatically a few more Hz with them. CPU up to 2.8Ghz from 2.7Ghz and GPU is at 585/600 and I have not tried to OC it more yet. The temps are great 25ºC/36ºC on the CPU and 28ºC/45~50ºC on the GPU (Idle/Load)
Alex
Very nice man:clap:
What cpu cooler did you have before the 9500?
I had a CNPS 7000Cu LED..... I can OC the CPU even more, but I need a better PSU. I was prime stable at 2.8+ Ghz, but wouldnt game. My guess is that the PSU didnt have juice for both CPU and GPU.
Alex
Originally Posted by AgonxOC
I came to the same conclusion when i had my new rig built yet constant 3d crashes. Turns out my old PC Power & Cooling 400w Silencer wasn't up for the job.
OCZ PowerStream 520W is on the way......
Alex
My rig, awaiting Phase. :)
(Compucase S411-SECC)
Front of case, with 120mm intake fan on the left.
Inside the case, with PCI support bar installed.
Inside the case, without PCI support bar installed.
Close up shot of Evo33 CPU cooler and RAM cooler.
7800GTX and Swiftech MCX159-R chipset cooler.
Internal wiring mess !
External wiring mess !
Temps:
Room temp (Same as average case temp with cover on !): 25C
Chipset temp: 30C
CPU temp (Idle): 36C
GPU temp (Idle): 41C
CPU temp (Loaded, peek temp): 44C
GPU temp (Loaded, peek temp): 52C
Clocks:
AMD64 Athlon 3000+ (1.8Ghz) Venice @ 2.7Ghz (300*9) / 1.525V (50% Overclock)
XFX 7800GTX 256MB @ 499Mhz/1350Mhz / Stock Volts (20% Overclock)
Corsair 2x 512MB TwinX XMS PRO CL2 @ 193Mhz 2-3-3-6-1T / 1.85V
3DMark06: 4311
my primary rig used for everyday functions:
http://students.uwsp.edu/jlosi341/
- Intel Pentium D 820
- Intel D945Psn
- HIS Radeon X800XL
- Seagate Barracuda SATA II 160 GB primary
- Seagate Barracuda SATA 300 GB storage
- 2x1GB G. Skill PC2-4300 DDR2
- NEC 3540 DVDRW
- Sony 1.44 floppy
- Enermax Liberty 620w
- Antec Sonata II case
- Thermaltake Big Typhoon
- Gigabyte wireless g pci card
- Windows XP Pro SP2
My 1700 clocking rig, function over form (It's got a case... does it count?:D )
http://www.insancen.co.uk/random/1700overall.jpg
http://www.insancen.co.uk/random/1700cooling.jpg
what it gets (Untweaked, Stock BIOS, booster not yet in there, so more to come:banana: )
http://valid.x86-secret.com/show_oc?id=69440
http://www.insancen.co.uk/random/2600+.jpg
My rig. just got a 3.73EE ES :)
http://img430.imageshack.us/img430/6920/pc34hp.jpg
My 6600 GT http://www.capoeirabrasil.free.fr/bo...l/Dscn0344.jpg
