Here's my contribution:
http://www.oc-papat.com/cp/kones/
Mulder's almost 4 years old now :banana:
CP :)
CP :)
Just finished mine....... :D
i finally got one! (too bad it's a kit... i feel so dirty)
http://img.photobucket.com/albums/v3...p/IM000355.jpg
i like the rad though... im probably going to swap out everything else lol
thats is the smallest tubing ive ever seen!
why is the fan outside of the case?
Tubing? Dunno what u mean. :)
The fan is in the sidedoor, so he is not "outside"! ;)
What blue LED fan is that? Looks good.
G
acidbaby, its IV line :p: lol
Those crazy euro guys and there 1/8" tubing :rolleyes:
Nice, I have similiar setup in progress only difference is pump location mine isQuote:
Originally Posted by racinjimy
below PSU. What fans on rad?
I actually am using panaflo L's. They aren't supposed to work with radiators this thick but I thought I'd try it anyway. I have no temp issues at all and I run them only about 1/2 way on my fan controller. I sealed around the metal shroud and between the shroud and the fans with foam tape.
My ambient temps are pretty low right now (18-20C), we'll see how this works in the summer!
Im european as well, and I use 1/2" tubing... :D :DQuote:
Another one of my Rigs.
love that rig special, nice use of the cube!
o.O nice, is that UV tubing, UV dye, or both?Quote:
Originally Posted by specialblend218
Clearflex with Dye-Lite UV dye.
Thanks for the coments guys. :toast:
i am loveing that case special, is it a mountain mod?
very sexy!
Yes, I love it too. So much easier to swap parts in this thing.Quote:
Originally Posted by jopers1986
Here's my little effort...
I have also added a pair of 80mm fans, one cools the RAM and the other cools the PWM IC on my DFI SLI-DR.
Nice, I am a big fan of the wave master.
Cashman - I think you probably said on EP-UK but why did you loose the phase change? I only ask because I'm wondering whether to move from phase to water.
Anyway - really like the look of your setup.
Hey Nicholarse,
I sold my Mach II GT because I was just fed up of a number of things. Sure the overclocks were amazing and the benchmark scores were something else.
These are the things that started to annoy me about the Mach II GT and my Previous Vapochill and why I changed to water:
1) Fedup of removing the mobo and ripping all the seal string off everythime I change CPU/Mobo.
2) My missus uses the PC for the odd letter or bit of work and I didnt like her using a PC running at its max OC for that. Esp as if summat went wrong, she would just leave it.
3) The amount of elec the unit uses was costly.
4) I never felt 100% comfortable leaving the PC on for 24 hours whilst I downloaded stuff off Bittorrent.
5) I got bored of Benching and only wanted a straight forward PC that would ALWAYS work and yet still allow me to OC and play my games.
6) I fancied a little bit of Silence :)
All in all I have loved my Phase change units but I now just want an easy life. So far Watercooling has been more fun and really nice and simple.
Argh! I really can't decide....
I agree with all of those things you say, but then I start thinking of the benches...
Here’s a pic of one of my water-cooled rigs.
This is my Barton 2500+ and external water-cooling case:
http://www.xtremesystems.org/forums/...id=28173&stc=1[/QUOTE]
Could you do some close up shots of your external box please. Great looking rig btw!
-Brandon
