-Boris-:shakes: so basically you can't show any proof because you ignore the current reality and instead you run to an alternative reality where you can find a 6C Llano ~3.7Ghz with <=125W TDP on working 32nm process but reality is way different..
I will now comment once more your false comments
1. perf/w (Full load (Linpack))
Power consumption - total system
FX 4M/8C 32nm vs Thuban 6C 45nm vs Deneb 4C 45nm
AMD Phenom II X4 980 [3.7 GHz, 4 cores] 209 100%
AMD Phenom II X6 1100T [3.3 GHz, 6 cores, turbo, AM3 +] 213W 102%
AMD FX-8150 [3.6 GHz, 4 modules, CMT, turbo] 231W 111%
FX 2M/4C vs FX 3M/6C vs Llano 4C everything on 32nm
AMD-3850 A8 [2.9 GHz, 4 cores] 165W 100%
AMD FX-4100 [3.6 GHz, 2 modules, CMT, turbo] 165W 100%
AMD FX-6100 [3.3 GHz, 3 modules, CMT, turbo] 172W 104%
Power consumption - CPU including converter
AMD Phenom II X4 980 [3.7 GHz, 4 cores] 126W 100%
AMD Phenom II X6 1100T [3.3 GHz, 6 cores, turbo, AM3 +] 124W 98%
AMD FX-8150 [3.6 GHz, 4 modules, CMT, turbo] 137W 109%
AMD-3850 A8 [2.9 GHz, 4 cores] 89W 100%
AMD FX-4100 [3.6 GHz, 2 modules, CMT, turbo] 77W 87%
AMD FX-6100 [3.3 GHz, 3 modules, CMT, turbo] 83W 93%
Performance-Index
AMD A8-3850 [2.9 GHz, 4 core] 100%
AMD FX-4100 [3.6 GHz, 2 Module, CMT, Turbo] 105%
AMD FX-6100 [3.3 GHz, 3 Module, CMT, Turbo] 115%
AMD Phenom II X4 980 [3.7 GHz, 4 core] 100%
AMD Phenom II X6 1100T [3.3 GHz, 6 core, Turbo] 106%
AMD FX-8150 [3.6 GHz, 4 Module, CMT, Turbo] 114%
-------------------------------------------------------------------------------------Final conclusion
link to the results I used in this summary
http://translate.googleusercontent.c...Tl4pCGBZpRIH9g
perf/w with 1.total system or 2. CPU including converter
1. AMD A8-3850 100%; 2. AMD A8-3850 100%
1. AMD FX-4100 105%; 2. AMD FX-4100 121%
1. AMD FX-6100 111%; 2. AMD FX-6100 124%
1. AMD Phenom II X4 980 100%; 2. AMD Phenom II X4 980 100%
1. AMD Phenom II X6 1100T 104%; 2. AMD Phenom II X6 1100T 108%
1. AMD FX-8150 103%; 2. AMD FX-8150 105%
As you can see almost every BD model has a better ratio compared to Llano 32nm or Deneb 45nm.
BD FX 8150 is short on perf/W vs Thuban but its kinda understandable because it needs 8 threaded applications to perform best but Thuban 6 threads and Deneb only 4 threads, the same can be said about FX 6100 because it needs 6 threads while the rest of the group only 4 while the tests were a mix from low threaded applications to highly threaded.
To be continued....:yepp:
