Basically I didn't have enough time to test different levels of stability with drives so I would change one and attempt to boot in to windows at a given frequency that was borderline unstable. If I was able to boot I kept the change, if not I reverted. I'd then up HTT 1 Mhz and try again, etc.
Hypers at 1900 7-7-6 are giving much better copy and write speeds than PSC at 2040 6-10-6, tightening to 6-9-6 hardly helped at all. I'm starting to wonder what the issue is.
As far as chips go with the Mushkins, are they rated 2000 9-11-9? I'd have to guess they are Hynix BFR as that is what is used on most of these high end kits...your snipers probably have the same if they can run 1900 9-10-9.
