ok here it goes mates passing my first time 14K no volts increase on GPU's just chip at x53 HT :)
http://img196.imageshack.us/img196/2336/sinttuloczp.png
Uploaded with ImageShack.us
cheers to all
Sergio
cheers to all
Sergio
Now thats what Im talkin about! nice bench there bro :)
If you want i can send you my EVGA bios.
My cards go 1000+ without problem, but temp. must be under 70-75°C
some vantage PPU OFF
http://img809.imageshack.us/img809/1116/sinttulo1vg.png
cheers all !
Sergio
is that watercooled andresergio?
how are you Honda ?
cards just air
chip on water yes
here my rig
http://img804.imageshack.us/img804/4113/p1090585p.jpg
cheers !
Sergio
Nice setup!
andreS
im just benching my 580...air cooling ftw LOL
980 is pure awesome for air + 1.150v.. at 1.150v my card only goes upto 920Mhz i believe haha! but it does 900Mhz at 1.088v
@honda: crazy clock @air. which voltage u used ? :up::yepp:
Dont kill my vid card honda :shocked: - how much volts for 1030?
Check PM too.
:up:
i'm back with some numbers! :) (waiting for my second evga coming back from rma!)
http://3dmark.com/3dm11/1347917 <-- 3dmark2011 Performance Single Card
http://3dmark.com/3dmv/3138565 <-- Sli 580 ppu off Vantage
http://www.xtremeshack.com/immagine/...94pegaz001.jpg
http://www.xtremeshack.com/immagine/...-peegaz001.jpg
http://www.xtremeshack.com/immagine/...ffpegaz001.jpg
@ andressergio i saw some of your numbers on hwbot :D
i dont know if im doing wrong but i see lots of ppl disabling feature tests...i shooted with them PPU OFF
cheers !
Sergio
those scores are ok, the important is disabiling PPU from 3dmarkvantage options :up:
OR disable physx from nvidia control panel, both ways has the same effect on the score _P
disabling features test it shorts the time of the bench since features test doesn't affect total gpu, and cpu score.
Hi Guyz,
I was running 3DMark Vantage with 965/1100 1.15V and the Cpu at 4.8GHz, when i went push the CPU at 5.1Ghz, the system reboot, so i thought that was the CPU unstability but, i tried again run the Vantage with the same settings and i got a reboot gain and the max now for my VGA is 920/1100, i tried 1.20V and 930/1100 and got reboot again.
Any ideia for solve this case ? hehehe
Hellooo Brasillll im from Uruguay mate !!!
well talking about that i had a similar experience yesterday that almost fainted...i flashed the card and tought it was cole bios that he kindly sent to me i was so stupid...so i pumped a bit to hit 2300 mem and when i hit apply i got a zillion artifacts on windows i wanted to die man, PC froze and since then i couldnt do my normal clocks without having heavy artifacts on 3DM11...so i flashed to original BIOS and all was nice again but i couldnt pass my 980 core...i get mad and then y flashed with cole's bios and no artifacts all perfect but couldnt pass no matter what volts. So i let things cool down and when i came back all fixed, i dont know if that bios from a modded evga i dlded once they tighten timmings or dunno but seriously screwed ma cards. Now i tried this and amazing
thanks cole ! btw beware that new patch of 3DM11 its lot points less
5400HT !!!
http://img30.imageshack.us/img30/8014/54003dm112.png
http://img143.imageshack.us/img143/2661/5400vant1.png
Helloo Hermano, hehehe
I will try the original bios, for now I measure the Vgpu when I set 1.175v and saw when was running Vantage 1.30V, yes 1.30V.
Now, i will flash again using original bios.
Thanks Man.
876MHz Afterburner 1.15 measure max 1.1690v
900MHz Afterburner 1.15 measure max 1.1695v
905MHz Afterburner 1.15 measure max 1.1693v
910MHz Afterburner 1.15 measure max 1.1696v
915MHz Afterburner 1.15 measure max 1.1674 REBOOT
Min voltage never bellow of 1.162v
I didn't get artifacts, i got reboot.
