if ure using vcore set to 1.445 and LLC 100%
ure close to 1.5v bud on load
u can still use LLC 75% but u need to be accurate. i use this up to 5.0 at 1.52v
with u raising vssa etc for mere 2133..
still dont think ure stable.
Well we will find out in a few hours. I started Prime95 this morning before work and it was still running after an hour when I left. Will see if it's still running when I get home.
Also, if you look in the Xtreme Bandwidth section you will see Chew had to raise his vccsa from stock for his 8-9-8-24-1T testing with my same set of memory, same MB and cpu. This is the first 12 hour stretch I have gone without any random blue screen 124bsods since I've reaised vccsa to 1.11v.
I am going to hook my mutlimeter up to the Board tonight to see actual vcore with LLC100%. CPUZ is reporting 1.45v when bios is set to 1.445v
With SP1 you get access to AVX instruction in windows, therefore you are able to stress your CPU beyond prime levels using LINX with AVX, otherwise ( without avx ) you should stick with prime, because it will stress your CPU more then LinX. You can confirm this using a killwatt or one of those nice piece of softwares that read CPU watts
What kind of issues/performance hit would I run in to using pciex16_1 and 2 for SLI instead of the suggested 1 and 3? I did not budget my space for using 1 and 3 :shakes:.
Also, are either (both?) of the molex 4 pin power connections on the board required, and what do they do? I read conflicting information that they are for SLI / Tri-SLI or are for USB power...
Thanks,
-sf
Use the two 4 pins, you dont loose anything in doing so... Not sure thought what they feed.
slot's 1 and 2 will give you SLI/CF using the NF200 bridge. You will take a sligth performance hit. 5% ?? due to the lag add by it.
I've got SLI 580s running in slots 1 & 3 without using either of the molex's on the board without any probs.
G.Skill RipjawsX 2133C8 @ 2133 6-9-6-24
http://i458.photobucket.com/albums/q.../21336-9-6.jpg
Well, I should have my board tomorrow. I'm excited and disapointed at the same time. No way to use my soundcard with trifired cards.:mad:
May have to send it back and get a UD7 with a waterblock for the board.:shakes:
Anyone knows how to fix issues between maximus 4 extreme and amd drivers?I keep getting BSOD while opening cpu-z vga tab,aida64 or aisuite,on windows7 64-bit...This happens only on amd vga's...
Also some cas6 testing with my new board :D
http://img200.imageshack.us/img200/6...2c6aida.th.png
Uploaded with ImageShack.us
full w7 install here, xp soon to come. . .
http://i52.tinypic.com/23kvfw4.jpg
http://i51.tinypic.com/315bara.jpg
what vga are you running :)?
Hmm,told ya,cpu-z keeps crushing my systen when i go to vga tab.Also i cant get aisuite to work properly,even if i applied that patch...What the name of the tool that displays voltages ?I was running 1.1 SA and 1.15 VCCIO.Ill try harder tomorrow,with proper tuning i hope ill reach at least 108 BCLK.
Well thing is that i have management engine installed :)
Thought so at first,but primming with 896K fft and memtest did not reveal anything...In my other OS,xp 32 bit i have no problems at all :) Also,could someone tell me how can i use offset voltage on maximus?Apreciated.
